Grade For Basement Floor Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2012, 08:53 AM   #1
Grade for basement floor drain?
Not sure if this is the right spot for this, but I am redoing my basement. The first thing I notice is the grade of the floor is pretty severely sloped towards the floor drain.
I have measured from the highest point of the floor to ceiling and from drain to ceiling and the difference is 2 1/2".
Does it need to be that sloped to drain properly? I was thinking of doing some self leveling stuff to flatten the floor out??
jdtox is offline   Reply With Quote
Old 01-10-2012, 09:33 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by jdtox View Post
...the grade of the floor is pretty severely sloped towards the floor drain.
whew! You would be surprised...
Did you verify that the ceiling is level?
The other dimension... from the drain to farthest point is ___?
Like this: at 1/8" pitch per linear foot... 2.5" (/.125") = 20 feet
Why? How do you use the room now? Do you plan to change that use?
And... how frequently do you experience water going down that floor drain?
hth
Old 01-10-2012, 09:42 AM   #3
hth
I am remodeling the basement to make it an entertainment space. I have not verified that the ceiling is level, but you can visually see the floor slope toward the drain.
Honestly is more annoying than anything. I dont recall seeing that bad of a slope in other peoples basements.
I have never experienced water going down that drain.
Old 01-10-2012, 10:04 AM   #4
Rewards Points: 14,000
I think I would go with sleepers.
That way there would still be a floor drain system, the floor would end up being warmer if you added foam between the floor joist.
Best way to grade for drainage around house? Bahuffma Building & Construction 7 08-01-2011 12:51 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Outdoor outlets jamiedolan Electrical 1 01-17-2009 11:15 AM
Below grade fireplace venting BillL HVAC 7 01-15-2008 07:20 PM
