Grab Bar Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2010, 01:28 PM   #1
grab bar replacement
I am trying to replace a broken acrylic grab bar in my Kohler one piece shower inclosure. The bar goes between two built in shelves. There are no openings or accessible attachment points. The shower enclosure is border by two walls. There is no access to either side or the back of the shower.
The grab bar is broken in the middle and I cannot pull out either piece. It must be attached on each end and only accessible from the back.
Any thoughts on how this can be replaced?
cjpeck is offline   Reply With Quote
Old 08-01-2010, 07:37 AM   #2
Grab bars are rarely acrylic, and they are made of such things that don't break. I suspect it is a towel bar. Grab bars need to be mounted into the house framing, or with specials attachment fixtures. Not sure what you have there, a pic would help. But I would consult a pro on this one. If it is a grab bar that is needed, it MUST be properly anchored or it could fail when needed most.
Old 08-01-2010, 08:54 AM   #3
You cannot pull the bars out you will break the tub. Twist the bars to loosen the adhesive and push the pieces in and let them fall behind the tub. Then either silicone in a new bar or cover the holes.
SuperPlumberGuy is offline   Reply With Quote
The Following User Says Thank You to SuperPlumberGuy For This Useful Post:
cjpeck (08-16-2010)
Old 08-16-2010, 02:34 PM   #4
Thanks, your information was right on!! but you knew that.
Any thoughts on how I can secure a new bar.. Kohler has no information on a replacement part so I thought I would buy a straight acrylic rod of the proper size but it will be loose unless I can secure it in some way.
Old 02-04-2011, 08:14 AM   #5
Source of Acrylic Rod
I, too, have this problem in a Jacuzzi tub. You can buy acrylic rod from McMaster-Carr at www.mcmaster.com. Just search for "acrylic rod". The cost is about $9 per foot for 1 1/4 inch diameter.
JB
jbgardiner is offline   Reply With Quote
Old 12-11-2011, 08:21 PM   #6
Me too
I have the exact same problem. I've tried to fix it several times. One day my son decided to push it into the wall and down it dropped! Now I have to find a new bar and figure out how to attach it. I would happily cover the holes if it would look good.
pauljval is offline   Reply With Quote
Old 05-23-2013, 10:25 AM   #7
Shower bar replacement
I know this thread is old, but I've had the same problem. a tenant managed to actually pull the bar out of the shower surround! Why? Who knows. So to repair a broken shower bar you need something called a bushing. Specifically mfg part number 611-6090
Bushings for 1" Acrylic Towel Bar (set of two)
For the moment http://uspartscenter.com/Bath-towel-bar.aspx seems to have the cheapest price. I am going to order these. I plan to use a PVC pipe as the towel bar part. It won't be pretty, but it shouldn't mold.
Good Luck!
Coupon Cook is offline   Reply With Quote
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
Questions about finding replacement blower motor revg HVAC 3 02-14-2010 07:39 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
Power Grab "glue"??? SillySally Remodeling 14 08-29-2009 11:29 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
