#1 |
goulds pump
Hi i am new to diy, however i have a goulds pp it was working fine but an a normal day using the pp the motor starts to chatter and making the motor over heat. can someone help me with this problem. thanks
#2 |
Whatamess
goulds pump
Is pp a power pump or pool pump or what. You need to provide more info about the problem. Pictures might help. Based on info it sounds like a bearing going bad.
I may go home hungry, but not tired and hungry. |
#3 |
Water quality'n pump guy
goulds pump
Yes, what is pp?
The pump is short cycling and overheating the motor which will kill the pump very quickly. So what are you using this pump for? If you have a pressure tank, have you checked the air pressure precharge to be 1-2 psi less than the turn the pump on switch setting with no water in the tank? I.E. 30/50 gets 29-28 psi with no water in the tank. |
| Display Modes | |
| Sump pump pit water level --- problem | de12 | Plumbing | 49 | 02-27-2011 02:42 PM |
| Sewer gas smell in basement from sump pump | mirage212 | Plumbing | 15 | 10-23-2008 07:09 PM |
| Foundation drain and sump pump | slatergrl | Plumbing | 3 | 02-10-2008 10:36 AM |
| sump pump continuing running | deck hand | Plumbing | 2 | 01-16-2008 05:35 PM |
| Well pump issue-should I be concerned? | Mikedks | Plumbing | 8 | 10-08-2006 11:42 PM |
