-   -   goulds pump (http://www.diychatroom.com/f7/goulds-pump-34825/)
toker 01-01-2009 02:59 AM
goulds pump
Hi i am new to diy, however i have a goulds pp it was working fine but an a normal day using the pp the motor starts to chatter and making the motor over heat. can someone help me with this problem. thanks:(
TazinCR 01-01-2009 06:46 AM
Is pp a power pump or pool pump or what. You need to provide more info about the problem. Pictures might help. Based on info it sounds like a bearing going bad.
Gary Slusser 01-01-2009 11:55 AM
Yes, what is pp?
The pump is short cycling and overheating the motor which will kill the pump very quickly.
So what are you using this pump for?
If you have a pressure tank, have you checked the air pressure precharge to be 1-2 psi less than the turn the pump on switch setting with no water in the tank? I.E. 30/50 gets 29-28 psi with no water in the tank.
