Gouging Brass Nipples-- How Not To - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2010, 08:57 PM   #1
Rewards Points: 135
Is there a special tool or technique so as to not cut into a brass nipple while tightening/loosening it?
smata67 is offline   Reply With Quote
Old 05-23-2010, 11:43 PM   #2
Rewards Points: 1,910
Use a properly fitting wrench works.
Old 05-23-2010, 11:55 PM   #3
use an internal pipe wrench. available at HD.
http://www.homedepot.com/h_d1/R-1006...atalogId=10053
romexican is offline   Reply With Quote
The Following User Says Thank You to romexican For This Useful Post:
Jim F (05-24-2010)
Old 05-24-2010, 09:32 AM   #4
fabrk8r
fabrk8r's Avatar
Buy a set of "fitting wrenches".
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-24-2010, 09:54 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Maybe it's just me, but how are those going to tighten a brass nipple??
Journeyman Plumber
Old 05-24-2010, 10:24 AM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
line wrences are for fittings,not pipe nipples.
i usually wrap a rag around the fitting before tightening with channel locks
plummen is offline   Reply With Quote
Old 05-24-2010, 07:09 PM   #7
Strap Wrench.we use it for chrome.You may be confusing the torque to loosen a nipple with what you need to tighten new nipple.If your gouging brass your tightening too much.you know about teflon tape,pipe dope and lamp wick?
bluejeans is offline   Reply With Quote
Old 05-24-2010, 07:26 PM   #8
fabrk8r
fabrk8r's Avatar
Oops...my apologies to the OP if I led you astray. I should drink a cup of coffee before I try to respond to posts that early in the AM. For some reason all I had in my mind was a brass compression nut. I guess it's because I've had alot of wrenches slip on them when I didn't have a line wrench.
As plummen said, a rag wrapped around the nipple is the technique I've always used to avoid damaging the finish of brass or chrome. I usually also wrap masking or duct tape around the jaws of the channel-locks or pipe wrench as an added measure of protection.
Old 05-25-2010, 09:44 AM   #9
Rewards Points: 135
I'm probably tightening too much. How do I know enough is enough?
I tried electrical tape on the jaws and did not work. I'm thinking a rag will slip. I am most recently wrapping threads in teflon tape then applying a coat of teflon paste. Sprinkler fitters do this.
The internal devices are a nice find, did not know they existed, will go into the toolbox.
How long to heat the brass fitting jgs1951 Plumbing 2 07-22-2009 10:19 PM
Need Tips To Unscrew 30-year Frozen Brass Pipe Fixture artdunbar Plumbing 4 03-12-2009 12:38 AM
3.5'' Brass Drain cleanout cover jeffmn Plumbing 6 01-13-2009 08:37 AM
Brass Plated Fixtures rjordan392 Plumbing 5 06-19-2008 10:19 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 03:40 PM
