Got A Studor AAV Valve Still A Question About Height! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 08:01 PM   #16
Originally Posted by Alan View Post
I don't really understand the way he referenced the AAV versus STUDOR argument.
An AAV is an air admittance valve.
Studor is a brand of air admittance valve.
The relationship really goes no further than that. I've heard the same things that he was touting to you over the phone, but in our code, it's an alternate method, which to me says : If there is no other way of doing it, then it's allowable.
he was saying those Pro Vents at HD are also called AAV they are cheap little plastic housing with a spring mechanism and the Studor also is an AAV but it does not work with any mechanical parts to wear out. I think it is like a piston sliding in a cylinder housing so that's the differentiation he said he believes some plumbers use AAV to describe any AAV but my questions is for those that say the see AAV's leak "all the time" are these black pro vents or Studor brand AAV vents usually mini-vents. If anyone has had Studor mini-vents fail "all the time" I'd hope you'd post about it. thanks
petros151 is offline   Reply With Quote
Old 07-16-2012, 08:46 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 676
I can't answer that because only recently(less then a year) have AAV's, a code definition, been allowed in my state.
And it's only under certain conditions.
And it's subject to the AHJ's approval.
And it must carry a UPC approval stamp.
Shower Valve Question dmpjr Plumbing 5 04-22-2012 07:37 PM
check valve question nsanto17 Plumbing 4 05-20-2011 08:04 AM
Dishwasher water inlet valve question Schweinehund Plumbing 0 01-29-2010 01:37 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 10:09 PM
