Is This A Good Water Feed Idea? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2010, 09:52 AM   #1
Is this a good water feed idea?
Not my kitchen but same layout.The sink is opposite the fridge.Currently I have no walls just studs left over from demo.Access to water from below will be more difficult.My thinking is to run the feed line up along a stud then across the top next to the joist then down the wall where the fridge is and stop half way down.Is this a good run? Any code violations about running across joists?Located in NYC.Any advice is appreciated.
nel262 is offline   Reply With Quote
Old 10-11-2010, 05:05 PM   #2
lloydb's Avatar
I'm not sure if it's a code violiation where you're at, can't think why it would be, but I've done nearly what you're suggesting.
I'd use 3/8 pex and reduce it at the fridge for improved water flow. I know it doesn't sound like it would make a difference, but it does.
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 10-11-2010, 07:52 PM   #3
Pex is a flexible tubing,yes? Why not 3/8 copper all the way around then reduce?
Old 10-11-2010, 08:43 PM   #4
lloydb's Avatar
Oh yeah, that's fine if you want. I just like pex cause it's cheaper and easier for me to work with.
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
