Good Tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2013, 08:31 AM   #1
Rewards Points: 43
Good Tub Faucet
What is a good quality brand tub faucet that doesn't leak any water when you pull the button up to run the shower?
The old one leaks like a sieve when the shower is on. I went and got a new Delta at Lowe's, it looked beefy with brass fittings, etc, but the rest of it is plastic!
Or is there a rubber washer that can just be replaced on the old one?
Thanks,
Al
AlleyG is offline   Reply With Quote
Old 04-02-2013, 08:39 AM   #2
DIY staff
Rewards Points: 7,174
I go to the plumbing supply house and usually get Moen----Delta mixers usually require a Delta spout,as they use a soldered on fitting---
I have never found a spout at a big box store that is anything but junk--------
jaydevries (04-03-2013)
Old 04-03-2013, 06:40 PM   #3
Taps (faucets)
Grohe are a good make as are Hansgrohe
plumbthat is offline   Reply With Quote
Old 04-03-2013, 07:17 PM   #4
Rewards Points: 636
i get mine at supply house also but i like to use delta pull down diverter and they have them in no sweat but i can not locat part number online
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
ben's plumbing (04-26-2013)
Old 04-03-2013, 08:04 PM   #5
sounds like all you need is a new tub spout. all of them leak a little water when using the shower.
Old 04-03-2013, 10:05 PM   #6
Roofmaster
Rewards Points: 2,172
Heres the one I use, does not drip at all. The wife doesn't think it looks "finished" I don't know why, I like it.
The Following User Says Thank You to jagans For This Useful Post:
Old 04-04-2013, 07:16 AM   #7
Rewards Points: 1,216
Now I know why your the roofmaster.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 04-04-2013, 07:18 AM   #8
Delta good stuff. Big box or supply house. Keep the original paperwork included with the fixture and call them any time for replacement parts.
Free.
Old 04-04-2013, 08:43 AM   #9
Roofmaster
Form Follows Function.
Old 04-04-2013, 10:22 AM   #10
dannyoung85's Avatar
I just bought an American Standard faucet for my shower from a supply house and it works great. The best part about buying commercial grade fixtures is that they are all solid metal, no plastic.
dannyoung85 is offline   Reply With Quote
The Following User Says Thank You to dannyoung85 For This Useful Post:
jagans (04-04-2013)
Old 04-26-2013, 09:59 AM   #11
Rewards Points: 43
I ended up getting the Delta pull-down style from a plumbing supply store. It was still plastic, but it works nice. At least with plastic you don't have to worry about pitting!
Al
Old 04-26-2013, 01:06 PM   #12
Good job alley plastic has been around a long time I'm sure you made a good choice. Delta simple yet easy to repair. Model number is the model number whether you buy it at a supply house, big box or flea market. Real commercial products are much different than house models. OK, tear me up all you parts buyers. Go to any commercial restroom you'll see the difference.
Old 04-26-2013, 01:21 PM   #13
Rewards Points: 712
You'll smell the difference too.
SeniorSitizen is offline   Reply With Quote
Kitchen Faucet Is Leaking Sycamore Inn Plumbing 23 11-14-2011 04:49 PM
Faucet with attached water lines. msaeger Plumbing 5 08-15-2011 10:19 PM
Anti Siphon faucet spewing water cai Plumbing 1 08-01-2011 03:48 PM
Good brand of kitchen faucet for an old home Stevoreno Plumbing 17 05-23-2010 07:33 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
