Good Toilets? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2010, 02:38 PM   #1
Rewards Points: 640
Good toilets?
I need to replace four toilets that are junk ones... any suggestions? I don't want to spend a ton of money on them... but I definatly want elongated, chair height (i think thats what the higher ones are called?) and of course uses as little water as possible but still has power... any suggestions? We were looking at a budget of $150 a toilet (not including the longer water connection or anything else we might need as needed) thanks!
BlueBSH is offline   Reply With Quote
Old 01-21-2010, 03:45 PM   #2
Licensed Engineer
Rewards Points: 171
Terry Love Plumbing
No kidding, that is the guy's real name. Check out his website for more information about toilets than anyone has any need to know. But I think your budget should be $200 per toilet as a minimum for an elongated bowl, ADA height, easy flushing, high quality comode.
MI-Roger is offline   Reply With Quote
Old 01-21-2010, 03:48 PM   #3
Rewards Points: 640
well if it needs to go to $200, thats what it will go to, just will skip the least used one for now to make up for the difference in cost thanks
Old 01-21-2010, 05:42 PM   #4
Rewards Points: 1,016
I really like the Toto G-Force toilets - elongaged, ADA, one piece (very easy to clean and keep clean), water saving with good flushing, etc. Pricing may be a bit more than your target budget, but worth it, IMHO.
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
How can I tell if my taping is good enough? yummy mummy Building & Construction 4 10-01-2008 10:16 AM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 09:16 PM
What would be good quality paint kenny357 Painting 13 06-07-2007 02:36 AM
