Good Nat Gas Fired HW Brand - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2012, 08:45 AM   #1
Rewards Points: 89
Going to replace the AO Smith 40 gallon unit I have,as I will be adding a 3/4 bath in my basement,making a total of 2 full,1 half,and 1 3/4baths in my house,should I upgrade to a 50 gallon,and if so,what is a good to excellent brand to get.
Thanks in advance for your inputs.
spring3100 is offline   Reply With Quote
Old 12-03-2012, 11:45 AM   #2
Special User
Rewards Points: 1,230
I prefer box store brands, because at 9:30pm on a Saturday I can run to my local store and grab a repair part off the shelf. If a big box store gas valve or burner assembly (or thermostat or element for electric WHs) fits into an AO or Bradley, then I guess I'd have no brand preference.
As for 40 vs 50g... I've had both. For one person at a time showering, including two people right after the other, 40g has always done the job for us. However 40g just can't keep up when filling a bathtub (nor, I suspect, with those fancy showers with multiple body sprays) unless you crank the thermostat up way past dangerously scalding temperatures. So that's why I just put a 50g in.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
How to find good window installer in remote rural area ThorpeJ Off Topic 8 03-12-2010 07:57 PM
Karndean Brand vinyl tile is it good stuff RegeSullivan Flooring 1 02-16-2010 05:56 AM
American Standard vs. any other brand can'tdecide Plumbing 2 10-05-2004 06:54 AM
