-   -   Good grief, 1956 American Standard bath faucet repair problem (http://www.diychatroom.com/f7/good-grief-1956-american-standard-bath-faucet-repair-problem-65518/)
David911 02-27-2010 03:02 PM
2 Attachment(s)
This morning I noticed our 1956 vintage bath faucet was dripping. No problem, right? Just take the existing cartridge out, go down to the store and get a new one, right?
So I get the old one out (hot side) and go down to the local big box store and find a new one. Get a cold side too since they're both old and I'll make everything new again. Get back home and get to work. Removed the old valve seat and replace it with the new one that came in the Danco kit. Take the new cartridge and install it and tighten everything back up. Go outside and turn water main back on (no shut off valves behind tub :mad: ) Go back inside and turn on hot water faucet... nothing :huh:. Whaaa?? Check the sink. Plenty of hot water there. Back to tub.... nothing. Back outside to shut off water main so I can pull cartridge back out. Checked it against the old one and they're identical. Pulled valve seat and compared it to the old one. Same. Put everything back together and turn water back on. Still no hot water.
If I loosen the nut that holds the stem assembly in place, I can get hot water to flow. Problem is, everything seems too loose if I leave it like that. Is there supposed to be some sort of washer between this nut and the valve body? I'm stumped. Here's some pics of the offending faucet.
Alan 02-27-2010 04:22 PM
Those spindles are pretty simple little devices. IF they are turning, and the stem moves outward from the wall, the opening should be clear.
You are 100% sure that they are the exact same spindle assembly?
Alan 02-27-2010 04:25 PM
Actually, did you install the spindles in the fully open position? That large nut is just a packing nut to hold the assembly in. Pull them back out, and open the spindle assembly all the way, then put it in, tighten the packing nut, and then turn the spindle to close.
If you install them with the spindle assembly CLOSED, your packing nut is tightening against the washer instead of the brass body. Then when you open it, the brass body is flopping around inside there and creating the loose feeling that you're having.
At least that's what I can gather from where i'm sitting. :huh:
David911 02-27-2010 04:30 PM
Been trying different things since I posted and if I put the rubber seal from the new cartridge onto the old cartridge, it works fine. I took the new and old shafts and held them up together without the rubber seals in place and there is a minute difference between the lengths. The new is about 1/16" longer. I wouldn't think that would make such a difference, but apparently it does.
The existing cartridge looks like it may have been replaced before. Tried to go online and find some info on the faucet, but it's like looking for a needle in a haystack :eek:.
David911 02-27-2010 04:33 PM
I've tried installing it both ways and no joy either way. The nut isn't your typical packing nut per se. It appears to run up tight to the cartridge assembly and press it in place. There's no seal associated with the nut.
