Good Frost Free Sillcock Brands? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2010, 09:43 PM   #1
Rewards Points: 91
good frost free sillcock brands?
I'm looking to install frost-free sillcocks at my house. Can anyone recommend a good brand? Thanks.
debiasio is offline   Reply With Quote
Old 08-16-2010, 10:48 PM   #2
Owner
LateralConcepts's Avatar
Legend
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-17-2010, 09:12 AM   #3
I like the Legend 1/4 turn valves, but they had some issues with them a few years back, specifically the ceramic cartridges getting corroded and leaking. I probably replaced a dozen of them over the last year or so. That said, they are easy to fix if you can find replacement cartridges, or you can buy a new one and take the cartridge out of it. I'll install just about any brand but Arrow and Woodford, those brands have proprietary parts that can be very hard to find
the_man is offline   Reply With Quote
Old 08-17-2010, 10:43 AM   #4
Chicago, IL
Michael Thomas's Avatar
A few things keep in mind when installing and using freeze-resistant hose bibs, based on problems I see at home and water intrusion inspections here in Chicago:
1) These hose bibs (sill cocks) are freeze-resistant, not freeze-proof – if you install them in locations were freezing temperatures are present at or behind the interior end of the valve (for example, because cold air is infiltrating the wall around the valve) the valves and/or the pipe behind them can still freeze and burst:
2) Often, I see these installed with an incorrect pitch, they must be installed with a slight downwards slope to prevent water form collecting in the valve down-stream of the valve seat:
3) If you leave a charged (water-filled) hose attached, the valve will remain filled with water even when "off".
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
TheEplumber (08-17-2010)
Old 08-17-2010, 08:29 PM   #5
Master Electrician
Rewards Points: 3,750
They will also freeze if a water filled hose is left attached through the winter.
brric is offline   Reply With Quote
Old 08-18-2010, 01:03 PM   #6
Rewards Points: 3,130
Prier. They are commercial grade (but kind've expensive).
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
frost free outdoor faucet question Roberta-mos Plumbing 5 05-16-2009 01:15 PM
frost free outdoor faucet etainabfr Plumbing 5 05-02-2009 10:59 AM
Frost free sillcock white29 Plumbing 5 04-29-2008 11:38 PM
