Going To Install New PVC For Sump Pump But Some Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2013, 01:39 PM   #1
Rewards Points: 160
Going to install new PVC for sump pump but some questions
Im going to finally install new PVC for the pump this weekend. I just want to make sure I have all the necessary parts because I hate making several trips to home depot or lowes.
I was wondering what the parts are called that are circled in yellow? I was just going for the same setup as it is now, but going with an 1 1/2in instead of 1in. Eventually I plan on routing the PVC underground towards the street, but thats for another day.
Going to install new PVC for sump pump but some questions-20130405_121543.jpg   Going to install new PVC for sump pump but some questions-20130405_122806.jpg
word2yamutha is offline   Reply With Quote
Old 04-05-2013, 02:24 PM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Looks like a union...
http://m.lowes.com/product?langId=-1...44&view=detail
They're nice to have a few feet from the pump so you can pull the pump out of the pit w/o having to cut your piping.
fetzer85 is offline   Reply With Quote
Old 04-05-2013, 02:44 PM   #3
Rewards Points: 582
don't see a check valve ..most pumps requirer them so you don't get back discharge after pump shuts off..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
fetzer85 (04-05-2013)
Old 04-05-2013, 02:58 PM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
Good point.
OP, can you take a couple up close pics of the pump? Sometimes the check valve is the first thing plumbed on to the pump outlet and if that's the case, it may still be attached to the pump.
Also, where does the pipe go outside?
The Following User Says Thank You to fetzer85 For This Useful Post:
ben's plumbing (04-05-2013)
Old 04-05-2013, 06:10 PM   #5
Rewards Points: 1,690
By IPC the check valve must be installed outside of the sump pit in a vertical position.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 04-05-2013, 08:40 PM   #6
Roofmaster
Rewards Points: 2,172
Thats a union, and I have never seen a sump pump down that deep in a sump pit. You better check the lift of the pump you have.
The Following User Says Thank You to jagans For This Useful Post:
Old 04-05-2013, 11:28 PM   #7
Rewards Points: 160
There is no check valve currently on this PVC line. Where would be a good place to install it? I have this pump http://www.amazon.com/Liberty-Pumps-...s=liberty+pump
Not sure why or who did this but the PVC outside of the house just shoots straight down next to the house. My plan to route it to the street.
Old 04-06-2013, 08:35 AM   #8
Rewards Points: 582
you may want to ckeck with your city...some places don't allow to discharge sump water on road surfaces in winter time can become icy.... as far as check valve we install them on the verticial side within 3-4 feet of pump....ben sr
Old 04-06-2013, 04:20 PM   #9
Do you have a drainage ditch by the road? If you have downspout drains run the sump to that.
ben's plumbing (04-06-2013)
Old 04-15-2013, 01:51 PM   #10
Rewards Points: 160
So I haven't gotten around to doing the install yet. I was wondering if I needed to install a union? I decided I'm going to level the pump with bricks. That only leaves me 2 feet from the pump to the basement floor, which I guess isn't enough space?
My last minute decision was to put in a a rubber check valve because they are more quiet and durable from my understanding.
http://www.amazon.com/Zoeller-30-018...ds=check+valve
From my understanding the union is suppose to be installed before the check valve but I might have to install it further down the line by like 5 feet.
Old 04-15-2013, 01:56 PM   #11
Rewards Points: 12,818
Do not need a union if you use that check valve.
Just loosen the clamp to remove the pump.
fetzer85 (04-15-2013)
Old 04-15-2013, 02:08 PM   #12
Always learning...
fetzer85's Avatar
Rewards Points: 262
As joe said if you use that check valve you won't need a union. It will serve as both a check valve and a union. Next time you need to remove the pump from the pit, just loosen both hose clamps on the top coupling, slide it up onto the pipe, lean the pipe attached to the pump a little bit and you can pull it right out of the pit.
I'm not sure what you mean by 2ft from the pump to the basement floor isn't enough space? Are you saying the french drains entering the sides of the pit are going to be below the base of your pump?
Old 04-18-2013, 09:04 PM   #13
Rewards Points: 160
thanks for the quick replies. I'm going to install without the union I'll update with pics when I'm finished.
EVAP coil install questions tndiyguy HVAC 25 08-04-2012 08:42 PM
Should we install a sump pump? Buster1 Plumbing 0 10-21-2011 10:24 AM
Sump pump questions Audioquest Plumbing 8 09-11-2010 02:40 PM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 03:26 PM
Range hood install questions drtbk4ever Building & Construction 6 10-09-2009 10:00 AM
