Old 04-27-2012, 05:52 PM   #1
going from copper pipe to PEX
hi; I live in Louisiana and I am building a custom shower and I am having to move the shower diverter. My question is I want to go from a 1/2 in. copper pipe to PEX hose I would like to know what the pluming code say to use on the copper pipe. a compression fitting a sharkbite fitting or to solder a nipple on then screw a PEX fitting on.
gbonin is offline   Reply With Quote
Old 04-27-2012, 06:09 PM   #2
shark bites or gator bites are legal here or you can solder on pex barb to the copper like in link
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 04-27-2012, 07:58 PM   #3
we use 1/2 copper x 1/2 pex and solder it on ...most homeowners perfer sharkbite user freindly...
Old 04-27-2012, 10:37 PM   #4
Doing it myself
Alan's Avatar
Pex adapter soldered onto the copper is a better way of doing it IMHO.
If you can't manage soldering, you can use a sharkbite, but o-rings do fail over time. I tend to only use them for qest repairs, or temporary water connections.
Journeyman Plumber
Old 04-27-2012, 10:40 PM   #5
Thanks I will solder on a PEX fitting I will feel better that way. I have used a sharkbite before but I was not real comfortable with in a closed up wall it did not leak but I still didn't feel reassured. I have used a compression fitting for copper pipe but I was not sure if it is to code.
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-14-2011 12:48 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 10:12 PM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General Discussion 3 09-05-2009 06:44 PM
