Old 08-22-2010, 08:40 PM   #1
Going from 1 Shower Head to 2
I am remodeling my master bathroom. I am needing advice as to how I can make my current shower head and add an additional one. I would like to have the option to have only one at a time working or both. Any advice would be great! Thanks
Almost Done! is offline   Reply With Quote
Old 08-22-2010, 09:09 PM   #2
Super Moderator
Does the mixer valve put out enough water volume to feed two shower heads?
Most dual shower head showers have two separate mixer valves--or use a single high volume mixer valve that is fed by dedicated 3/4 inch pipes.----Mike---
Old 08-23-2010, 09:19 PM   #3
Still going...
ChrisDIY's Avatar
The simplest way I have ever seen is the Kohler K-9511 This diverter allows two shower heads one stationary and one on a hose. I plan on using this in my master bath when I get to it.
--Chris the DIY Guy
Still going, on Ibuprofen...
ChrisDIY is offline   Reply With Quote
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-25-2010 12:31 AM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 04:08 PM
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 07:38 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 12:23 PM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 06:49 PM
