Go No-go Tool - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2007, 08:47 PM   #1
Rewards Points: 93
go no-go tool
Im doing my first crimps on my pex and didnt want to continue without making sure of a couple things.
First off once i finished my crimp, i use the go no-go tool. The go side fits no problem, but are you supose to be able to turn it right around? Theres one little point where its tight and needs a little push to continue, but i cant twist it right around.
Second, if i do a crimp wrong, can i re-use the fitting after taking the ring off?
simonb is offline   Reply With Quote
Old 09-19-2007, 08:56 PM   #2
Rewards Points: 93
I forgot to mention, the no-go side doesnt fit, but if i push hard enough i can get it to fit, im thinking this is normal.
Old 09-20-2007, 07:10 AM   #3
RippySkippy's Avatar
Originally Posted by simonb View Post
...go side fits no problem, but are you supose to be able to turn it right around?
...can i re-use the fitting after taking the ring off?
My GNG will go around the crimp ring...the no go side will not, not even if I push hard. You might want to check the settings on your crimping tool. You can reuse the fitting after removing it...if you're using copper rings, did you pick up a ring splitter? It makes the task of removing the rings very easy...and while they are pricey, salvaging a few fittings covers the cost.
RippySkippy is offline   Reply With Quote
Old 09-20-2007, 12:00 PM   #4
Rewards Points: 93
Well i tried to adjust the tool from 0 to 1, that setting is too tight and the no go side fit no problem, so i know setting 0 is just fine. This is the compact version of the tool, i rented it at home depot. Should there be a concern if the no-go doesnt fit without a hard enough push and if i cant got completly around with the go side, about 90% will go around
I won't burn this luxury tool, right? KUIPORNG Remodeling 15 03-09-2007 04:11 PM
Is this Cutout Tool OK? ADKstorm Tools 3 01-24-2007 01:08 PM
FS: RamSet "Cobra" Powder Actuated Tool... DIYinTO Tools 2 07-31-2005 03:32 PM
