Gluing ABS Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2009, 12:26 PM   #1
Gluing ABS Pipe
My question is about ABS 3" pipe
l've roughed in my toilet 12" from the finished drywall. l now want to install tiles and therefore need another 5/8". l have yet to secure the toilet flange to the sub floor and therefore can pull the flange 5/8 from the wall which in turn is bending the 3" pipe and connections running from the flange to the main stack about 4' away. So my question is will this stress on the glued ABS joints over time loosen and start to leak?
daz49 is offline   Reply With Quote
Old 01-29-2009, 12:39 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I've had ABS drain pipes in my home since it was built in 1977.
In my opinion and experience, the answer to your question may be "yes".
If it were me, I would simply cut the pipe and add another coupling or two to relieve the joint stress, using ABS glue only of course.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-29-2009, 03:36 PM   #3
Registered User
Termite's Avatar
PVC and ABS glues "weld" the pipes together, essentially creating one piece of pipe.
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
