Glueing Onto Painted PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2009, 01:08 PM   #1
WaldenL's Avatar
Rewards Points: 268
Question
Glueing onto Painted PVC
I need to splice into an existing PVC waste pipe in the basement. Unfortunately that pipe has been painted white. If I clean it and apply the PVC glue will that work with the paint on the pipe? I worried that the glue won't melt through the paint.
Thx,
-Walden
WaldenL is offline   Reply With Quote
Old 01-13-2009, 01:53 PM   #2
bradnailer's Avatar
I'd take a little fine grit sand paper and very easily sand off the paint, then prime and glue.
bradnailer is offline   Reply With Quote
Old 01-13-2009, 02:03 PM   #3
RippySkippy's Avatar
Use some PVC cleaner...it'll strip most if not all of the paint right off. Then prime, and glue as you normally would. Not a problem.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 01-13-2009, 02:38 PM   #4
WaldenL's Avatar
Rewards Points: 268
"Cleaner" is different from "primer", or just the normal purple stuff like this: http://www.lowes.com/lowes/lkn?actio...244&lpage=none
Old 01-13-2009, 03:49 PM   #5
Registered User
Termite's Avatar
I think that I'd sand most of the paint off first. Use the primer and see if it takes the rest of the paint off.
Old 01-13-2009, 04:01 PM   #6
Yup...cleaner is different than primer. I don't like the primer and cleaner combo stuff for tasks like you're trying to do. Give the cleaner a whirl...
LMASD
Old 01-13-2009, 08:37 PM   #7
I see this very often on CVac pipe... I scuff it with the back edge of a utility knife or thumb nail. Fine steel wool, nylon scrub pad, cleaner all should work but you don't want to reduce your pipe size.
Easy does it or you'll need pipe stretcher!.
Chemist1961 is offline   Reply With Quote
Old 01-13-2009, 08:51 PM   #8
WaldenL's Avatar
Rewards Points: 268
Originally Posted by Chemist1961 View Post
... but you don't want to reduce your pipe size.
That's what I was worried about (reducing the pipe size)... and I hear those pope stretchers are EXPENSIVE!!!!
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 11:50 AM
Sheetrock mudding over existing painted textured surface? SKINNY Remodeling 8 10-13-2008 12:00 PM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 03:55 PM
