Glueing ABS Pipe!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2012, 07:13 AM   #1
glueing ABS pipe!!
Hi folks,
I have a noob question, but I am in the process of building an aquarium over-flow and was wondering if I can glue the ABS pipes using "silicon I" instead of the ABS bonding glue.
when i was at home depot the guy who helped with the ABS pipes showed me the glue for the ABS, but after I read all the (caution signs, poisonous....) on the can I hesitated to buy the bonding glue that contain (methyl ethyl ketone, and acetone....) so I am wondering if I can get away with joining the pipes using silicon and get a air-tight seal.
any help is appreciated.
vanny123 is offline   Reply With Quote
Old 12-21-2012, 07:23 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Originally Posted by vanny123 View Post
Hi folks,
Ayuh,... It's used to glue the joints,...
Yer not drinkin' the stuff...
The odds are, if ya use sillycone, it's leak, eventually...
Btw,.... Sillycone is Poisonous too...
Old 12-21-2012, 07:38 AM   #3
haha, no im not going to be drinking the stuff... it is going to be used for my salt water aquarium.
and the silicon is labelled aquarium safe..
but the leaking part is what worries me
Old 12-21-2012, 08:55 AM   #4
Roofmaster
Rewards Points: 2,172
Open the window and use the correct glue. Cant you glue the pipe part outside, Let it set, and then put it in the tank?
Old 12-21-2012, 08:59 AM   #5
its not that I'm glueing it on the tank.
first I'm assembling the over flow, then glueing it with silicon (or abs bonding glue if its okay)
then washing the whole thing and testing it.
then i assemble it on the tank.
im not sure if it is okay to use the ABS glue or use the silicone.
it needs to be water tight... any recommendations!
Old 12-21-2012, 09:39 AM   #6
Roofmaster
You use the proper primer and glue for ABS Pipe, what is it that you dont get about this, or am I missing something?
Old 12-21-2012, 10:13 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Here's a question : You're worried about the ABS glue, but did you ever think about the pipe itself? DWV piping is not tested for potability.
Journeyman Plumber
Old 12-21-2012, 10:20 AM   #8
no the pipe is okay, most of the equipment in the aquarium trade is made from ABS. so i doubt there be a problem.
Old 12-21-2012, 10:23 AM   #9
read my first post. I would use the proper glue... however, the glue is toxic and poisonous so i cannot use it for piping installed on an aquarium as it will harm the livestock inside.
so the question was can i use silicone that is aquarium safe?
Old 12-21-2012, 10:42 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 824
Hi folks,
Those ketones are VOC's that will evaporate quite quickly. To a good extent, the black ABS cement is really more of a desolver. It does it's job of glueing the two pieces together by desolving the ABS plastic. The emulsion that it's in is essentually a carrier to allow you to put it where you want it. Once you glue those pipes, I would say the ketones are totally gone within 24 hours. If your really worried about it...give it a week.
The issue with silicone is that it will not bond to the ABS. Hence, if you have any movement of the joints...good chance it will eventually leak.
ddawg16 is online now   Reply With Quote
Old 12-21-2012, 10:48 AM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 352
We are plumbers or people experienced at using only ABS glue. My guess is about as good as yours. The fittings have very tight tolerances and do not completely seat unless the proper glue is used- MEK softens the plastic and actually welds the pipe
Did you know that ABS and PVC/DWV pipe is cellular and will float?
Old 12-21-2012, 11:26 AM   #12
Plumber
Are sure your not talking about PVC ?
DidIDoThat is offline   Reply With Quote
Old 12-21-2012, 06:52 PM   #13
Rewards Points: 582
what is all the fuss about.. glue pipe let it dry good ..should be fine...ben sr
Old 12-22-2012, 01:43 PM   #14
Rewards Points: 1,092
pvc can be used for potable water for humans, and abs should not. i'd use pvc and don't worry one second about the primer and/or glue doing jack stink once it is dry. as said, glue outside or with a window open. silicone on plastic pipes is as useless as boobs on a bull.
Old 12-22-2012, 04:42 PM   #15
HAHAHA nice analogy
any ways here is an update. since i am stubborn and ask for advice and don't take it I went ahead and tried out the silicone and not much to my surprise it did fall apart after it was filled with water (in bath tube of course)
so for others out there as the plumbing people said silicone on ABS is useless.
So now I went ahead and purchased the ABS glue and hopefully it will work properly this time (Ill do it outside) and let it cure for 24 hours so all the hazardous vapours go off and then ill wash it and then hopefully set it up on my fish tank.
also I would have bought PVC but the fact is that Home Depot did not carry 1.5 inch pvc and sold it at 100 feet which is too much.
i dint know where to buy it, and now its probably to late.
Tags
abs , aquarium , glue , silicon
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-26-2012 12:58 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
