-   -   glueing ABS pipe!! (http://www.diychatroom.com/f7/glueing-abs-pipe-167045/)
vanny123 12-21-2012 06:13 AM
glueing ABS pipe!!
Hi folks,
I have a noob question, but I am in the process of building an aquarium over-flow and was wondering if I can glue the ABS pipes using "silicon I" instead of the ABS bonding glue.
when i was at home depot the guy who helped with the ABS pipes showed me the glue for the ABS, but after I read all the (caution signs, poisonous....):nuke: on the can I hesitated to buy the bonding glue that contain (methyl ethyl ketone, and acetone....) so I am wondering if I can get away with joining the pipes using silicon and get a air-tight seal.
any help is appreciated.:wallbash::thumbup:
Bondo 12-21-2012 06:23 AM
Originally Posted by vanny123 (Post 1077228)
Hi folks,
Ayuh,... It's used to glue the joints,...
Yer not drinkin' the stuff...
The odds are, if ya use sillycone, it's leak, eventually...
Btw,.... Sillycone is Poisonous too... :whistling2:
vanny123 12-21-2012 06:38 AM
haha, no im not going to be drinking the stuff... it is going to be used for my salt water aquarium.
and the silicon is labelled aquarium safe..:thumbup:
but the leaking part is what worries me:(
jagans 12-21-2012 07:55 AM
Open the window and use the correct glue. Cant you glue the pipe part outside, Let it set, and then put it in the tank?
vanny123 12-21-2012 07:59 AM
its not that I'm glueing it on the tank.
first I'm assembling the over flow, then glueing it with silicon (or abs bonding glue if its okay)
then washing the whole thing and testing it.
then i assemble it on the tank.
im not sure if it is okay to use the ABS glue or use the silicone.
it needs to be water tight... any recommendations!:)
jagans 12-21-2012 08:39 AM
You use the proper primer and glue for ABS Pipe, what is it that you dont get about this, or am I missing something?
Alan 12-21-2012 09:13 AM
Here's a question : You're worried about the ABS glue, but did you ever think about the pipe itself? DWV piping is not tested for potability.
vanny123 12-21-2012 09:20 AM
no the pipe is okay, most of the equipment in the aquarium trade is made from ABS. so i doubt there be a problem.
vanny123 12-21-2012 09:23 AM
read my first post. I would use the proper glue... however, the glue is toxic and poisonous so i cannot use it for piping installed on an aquarium as it will harm the livestock inside.
so the question was can i use silicone that is aquarium safe? :)
ddawg16 12-21-2012 09:42 AM
Hi folks,
Those ketones are VOC's that will evaporate quite quickly. To a good extent, the black ABS cement is really more of a desolver. It does it's job of glueing the two pieces together by desolving the ABS plastic. The emulsion that it's in is essentually a carrier to allow you to put it where you want it. Once you glue those pipes, I would say the ketones are totally gone within 24 hours. If your really worried about it...give it a week.
The issue with silicone is that it will not bond to the ABS. Hence, if you have any movement of the joints...good chance it will eventually leak.
TheEplumber 12-21-2012 09:48 AM
199 Attachment(s)
We are plumbers or people experienced at using only ABS glue. My guess is about as good as yours. The fittings have very tight tolerances and do not completely seat unless the proper glue is used- MEK softens the plastic and actually welds the pipe
Did you know that ABS and PVC/DWV pipe is cellular and will float?
DidIDoThat 12-21-2012 10:26 AM
Are sure your not talking about PVC ?
ben's plumbing 12-21-2012 05:52 PM
what is all the fuss about.. glue pipe let it dry good ..should be fine...ben sr
jklingel 12-22-2012 12:43 PM
pvc can be used for potable water for humans, and abs should not. i'd use pvc and don't worry one second about the primer and/or glue doing jack stink once it is dry. as said, glue outside or with a window open. silicone on plastic pipes is as useless as boobs on a bull.
vanny123 12-22-2012 03:42 PM
HAHAHA:laughing: nice analogy
any ways here is an update. since i am stubborn :bangin: and ask for advice and don't take it I went ahead and tried out the silicone and not much to my surprise it did fall apart after it was filled with water (in bath tube of course)
so for others out there as the plumbing people said silicone on ABS is useless.
So now I went ahead and purchased the ABS glue and hopefully it will work properly this time (Ill do it outside) and let it cure for 24 hours so all the hazardous vapours go off and then ill wash it and then hopefully set it up on my fish tank.
also I would have bought PVC but the fact is that Home Depot did not carry 1.5 inch pvc and sold it at 100 feet which is too much.
i dint know where to buy it, and now its probably to late.
