Glue (cement) For Plastic And ABS - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2011, 02:52 PM   #1
Glue (cement) for plastic and ABS
Ikea sink came with some cheap plastic pipes that I have to connect to my existing ABS pipe. I have seen glues for transition from ABS to PVC but I have never seen one for plastic.
Is there specific glue for this or can I just use one for ABS pipes??
agapediy is offline   Reply With Quote
Old 04-18-2011, 03:18 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Usually the sink is connected to the drain via a slip nut trap and fittings, hence no cement required. Post a picture of the sink and drain for additional info. Also what material is the cheap plastic pipe?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-18-2011, 03:35 PM   #3
The entire plastic drain pipe itself doesn't require any cement. However, the original ABS pipe is 1 3/4" (I'm not 100% sure about the pipe size) and cheap plastic pipe that came from IKEA is 1". Therefore, I need a reducer to connect those too and the cement is required (I think) to make this work.
The below is only picture I got at this moment. Do not think that it is PVC pipe just because it is white. It's much thinner than PVC or ABS pipe (You can easily pinch it with your fingers) . I think it's just pure plastic.
Old 04-18-2011, 03:47 PM   #4
A "Handy Husband"
rjniles's Avatar
Looks like standard PVC 1.5" slip joint fittings to me. Does not look like ABS. What and where is that arrangement located?
Old 04-18-2011, 03:53 PM   #5
Do you see a black pipe at the end of the drain? That is the existing ABS that I trimmed down. I really don't think that they are PVC and they are only 1".
Old 04-18-2011, 04:24 PM   #6
A "Handy Husband"
rjniles's Avatar
Sorry but I need more and better pictures. I do not see what you are talking about.
Old 04-18-2011, 04:48 PM   #7
Hope this is going to help. The vanity hid the p-trap nicely lol so I drew it on the pic.
Old 04-18-2011, 05:20 PM   #8
A "Handy Husband"
rjniles's Avatar
Aah, now I see said the blind man
There should be a trap adapter on the ABS pipe going into the wall that allows the connection to the slip joint PVC trap
Not sure what that piece that looks like a tree coming up from the P-trap. Do you have a picture of the sink drain that you are trying to install. And is the plan to remove one of the sinks in the picture?
Old 04-18-2011, 05:24 PM   #9
For that trap adapter, you don't have to use a cement?
It's a double sink unit which is the reason for a tree coming up from the p-trap.
Old 04-18-2011, 05:42 PM   #10
Owner
LateralConcepts's Avatar
I don't know what that tree thing is either. I've never seen such a goofy thing. Are you in the United States?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-18-2011, 05:49 PM   #11
I'm in Canada but I believe this is how they do it in Europe since it's from IKEA.
What does the typical setup look like then?
Old 04-18-2011, 06:02 PM   #12
A "Handy Husband"
rjniles's Avatar
Canada, eh. That tree is nothing I have seen. I see the 2 drains coming from the sinks. but what are the 2 stubs above that? The trap adapter is already cemented to the ABS drain, you should not have to mess with it.
Still not sure what you are doing. Are you removing 1 or both of the existing sinks to install the new one?
Old 04-18-2011, 08:26 PM   #13
Owner
I'm assuming you're switching to a double vanity? His 'n her sinks?
It appears your cabinet and/or drawer slide is in the way.
Hard to tell from your picture.
A lav drain however, shouldn't be any smaller than 1 1/4". 1 1/2" is better. The drain in the wall also shouldn't be any smaller than that.
Lateral
(208) 818-8241
Old 04-18-2011, 08:49 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 556
That appears to be a modified center outlet waste. The 2 wyes at the top that looks like disposal connections are prolly the lav overflow connections. Seen similar arrangements in motels that have cultured marble lavs
Standard lav drains are 1 1/4". get a 1.5" ABS trap adpt. with a reducing slip nut for a new 11/4 trap
