-   -   Glacier bay all in one sink faucet low pressure -- aerator clean (http://www.diychatroom.com/f7/glacier-bay-all-one-sink-faucet-low-pressure-aerator-clean-171352/)
benwa100 02-07-2013 10:12 PM
Hi Everyone,
I installed the following sink and have kinda low water pressure.
http://www.homedepot.com/Glacier-Bay...1#.URR3AidFlPI
I'm not sure if this type of sink simply has low pressure or if something is wrong.
When I take out the aerator, it looks perfectly clean. Also, when the aerator is out, the water comes out of the sink with decent power (I think) but it obviously sprays all over the place without the aerator. As soon as i put the aerator back in, the water pressure is pretty weak (but still basically useable).
Does this sound like the faucet simply has low pressure or is there something I can do to fix it?
Thanks!
joecaption 02-07-2013 10:55 PM
May have a flow restrictor. Looks like a washer with a small hole in it, pop it out and see what happens.
Hope you know you bought the cheapest of the cheap faucets so do not expect to much from it as far as finish lasting for long and not leaking.
oh'mike 02-08-2013 05:59 AM
If that has a pull out sprayer--let us know----there is a back flow valve built int the hose that frequently clogs up---
Have you checked the shut offs ? How about the feed lines? Are they nice and straight with no kinks?
Those are poor quality as you have already found out---only one did I install one---(fix up for sale job)--I was not impressed---------
percygreen 02-08-2013 07:24 AM
It's been my experience that anything marketed as "all in one" is usually garbage. (Sinks with faucets already installed, the infamous "Toilet-to-Go" at Lowe's, etc). The idea is for the big box stores to sell something that's easier and quicker for the homeowner to install himself, negating the need for a plumber. Unfortunately, most of the time this stuff is of inferior quality, and you'll end up paying a plumber to either fix it or replace it anyway.
jagans 02-08-2013 09:16 AM
I remember when $300 bucks was a lot of money. :(
benwa100 02-08-2013 09:21 AM
Thanks for the responses so far. The faucet does have a pull out sprayer (the faucet is on a hose and you push a button on the faucet to make it a sprayer). The pressure is about the same whether I have it on sprayer or regular mode. I couldn't find a flow restrictor. The shutoffs are open and the feedlines seem straight to me. I'm not sure how to clean out the "back flow valve built int the hose that frequently clogs up"".
In general, this is the first diy plumbing I have ever done, so I don't really know what I'm doing or the terminology.
marleyeds 09-21-2013 09:08 AM
I'm having the same flow issue - and same story as you regarding taking the aerator off. Valves are all set, not kinks...this thing has to have a restrictor somewhere. Wish I would have had time to read the reviews on this one!
oh'mike 09-21-2013 09:38 AM
See if there is a tiny back flow gizmo where the hose screws into the valve body---
look in the hose end---or inside the outlet on the valve body----Moens back flow fitting pops out when you turn on the water with the hose removed---use a bucket to catch the little part---
jagans 09-21-2013 10:19 AM
Pull the cartridge. A lot of carts have filter screens in the cart itself right where orings bear against a base plate. There should be a set screw to remove the handle. Of course turn off the H&C feeds first, open the faucet to bleed off pressure and pull the cart. Probably crap in there.
Ghostmaker 09-21-2013 06:52 PM
How was your pressure on the old faucet. What type of waterline do you have?
Galvanized steel, copper,CPVc or Pex
jmon 09-21-2013 11:17 PM
Originally Posted by benwa100 (Post 1112133)
Hi Everyone,
Thanks!
When you took off the aerator you said you had decent pressure/power (you think). Just a suggestion, check your faucet to see if the flow restrictor is installed on its own or whether it's part of the aerator. If it's on its own, you can remove it easily (but said you can't find it). My guess is; That it's part of or built into the aerator itself. Try a different aerator.
gregzoll 09-22-2013 12:23 PM
The other item to look at, is how old are the shut-offs. They get gummed up with crud over the years, and worth replacing, if you cannot remember how old they are.
Ghostmaker 09-22-2013 02:29 PM
Your age is showing...:eek:
jagans 09-22-2013 06:16 PM
Thanks Ghost, I needed that. :huh:
ohyeahthatchick 04-14-2015 02:02 PM
I know this is an old thread, but I had the same issue this week. We bought the sink because it's an awesome sink with a nice big deep main bowl. The faucet was just a bonus.... until we hooked it up and realized that there was hardly any pressure from the thing. And we knew it wasn't my pipes because the older faucet I had was such high pressure that you couldn't even turn it on all the way without water splashing everywhere. I'm used to taking out flow restrictors in shower heads and all, but I had no idea they did it to kitchen faucets now as well. So when I realized that the pull out spray head was more like a pull out trickle head and it took 5 minutes to fill up a pot of water, the search for the little plastic thing began...
I fully took apart the head because that seemed to be where most of these things are, but no... nothing I took out helped. So don't even bother with taking the head apart or you might mess up the switch in it. And as mentioned, taking the aerator out doesn't help one bit.
The next day the boyfriend started to work on it. He un-clicked the little white quick connect coupling going from the hose to the water line and lo and behold, there it was. Or rather, there THEY were Basically, just disconnect the quick connect coupling, unscrew the white plastic t-shaped piece from the black faucet hose, take out the small black washer, and then stick a pencil or something into it and TWO little white cartridges with blue rubber rings pop out. Push the little black washer back in, reconnect the hose, and bam... you have water pressure again. What surprised me is that there are two of these things in it, not just one. No wonder it was so bad.
Here's a picture of what they look like since no other threads I've found have actually shown them: http://imgur.com/wYgV90o. I'm not sure if these are flow restrictors or back flow cartridges, but they are what was causing the massive drop in water pressure.
Again, I know this thread is old, but I hope it will help others who run into the same issue with this Glacier Bay all in one sink. I know the faucet isn't top of the line like Moen or Delta, but it's a good deal considering how nice the sink itself is and the price of similar faucets. I'm just using it until I feel like shelling out money for something nicer or until it starts leaking or breaks.
