This is a silly problem compared to some of the major plumbing repairs posted on this site. Right now I'm tackling removing those rubber(?) non-skid pads off the bottom of our fiberglass shower. They've been on there for so many years that they're like dry rotted on, and using fingernails, they come off in hundreds and hundreds of tiny bits. I don't want to use a razorblade to pry these off in case I scratch/hurt the fiberglass. A rubber scraper won't work because the scraper's end is not thin enough to slid under the pads. Would some kind of adhesive remover work? Something that won't hurt the finish?
I think paint thinner will also remove the adhesive. I did this many years ago myself. You might also try using a hair dryer or heat gun to soften the adhesive first, then peel them up. Then use paint thinner to remove the residue.
Goof Off will probably also work, I just think paint thinner is cheaper and you're more likely to already have it!
Thanks for all of your suggestions. I will give them a try. Is mineral spirits the same thing as paint thinner? If so, I do have that around that I can use first before buying the Goof Off.
I have a little concern about putting these products on the fiberglass shower. You don't think they'll ruin the finish?
I would go with hair dryer heat and something like Oops! or any other adhesive solvent such as suggested by Ron. That stuff will dissolve bubble gum right out of hair, and won't hurt a fixture surface.
Mike
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
