| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Raised Garden Beds: Drainage System 2
by Expert Village
We have a second bathtub that we're going to be treating a little bit differently so we have two that we're going to be working with. The drainage system that we're going to use in this one is going to be from a PVC pipe. This is a thin walled what is... Read More »
How to Thaw Frozen Pipes
by eHow.com
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Drilling the A Pipe for a Xylophone
by Expert Village
So, the next step we're going to do is drill the A. We need to drill the A so we can attach it to the xylophone bar. The way we're going to do that is just like with the C and the B. We're going to put it into the pipe grip on our vice here. Attach it in... Read More »
Basement Remodeling: Bathroom Plumbing & Fixtures
by Expert Village
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Raised Garden Beds: Install Drainage System 2
by Expert Village
Okay we are here at tub number 2 and we are finishing the drainage system with using PVC pipe. You will notice that I've only drilled holes on one side. The other side of the pipe is intact. We are going to roll the pipe over so that the holes are to the... Read More »
