Getting Pipe To Point In The Right Direction - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2012, 09:25 AM   #1
Rewards Points: 135
Getting Pipe to Point in the Right Direction
I'm installing a rigidly mounted hose bib, frost free type, comes through the wall into the basement. I'm using threaded connections, all brass. I need the elbow I screw into it to point in a certain direction. How do pipefitters manage to do this? If for example, I'm getting pretty tight at 9 o'clock, but need it to point to 3 o'clock, is it a matter of just torquing it to that point? Or do I untighten counterclockwise and see if it leaks in the looser position. Will pipe dope work better than tape to accomplish alignment?
smata67 is offline   Reply With Quote
Old 03-21-2012, 09:33 AM   #2
If you can get it to go from 9 to 3 then your all set. Another option is to use a compression fitting, point the pipe in the desired position and then tighten the compression fitting to hold that position.
I'd use teflon tape with brass (just my preference).
Helper328 is offline   Reply With Quote
Old 03-21-2012, 12:38 PM   #3
MarginallyQualified
Rewards Points: 2,464
May I ask why?
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 01:48 PM
anybody want to clear something up for me? Pressure bfan781 Plumbing 10 06-12-2011 06:52 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
