Getting Pipe Dope Off PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2012, 12:12 AM   #1
Getting pipe dope off PVC
Hi all-
A couple days ago I boobed and used pipe dope on some threaded PVC fittings on my sprinkler manifold. They are all leaking now. Anybody know what will remove this stuff from the fittings without damaging the PVC? I'm gonna try to clean it up, prime it, glue it. Hope that works. Thanks to anyone that replies.
- Greg
haddonfield78 is offline   Reply With Quote
Old 09-04-2012, 06:30 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Just use a rag and wipe it off. Depending on the type used, water should disolve it.
Then use about 4 wrapes of teflon tape. The tape is not what seals it...but rather reduces the friction of the threads and lets you get it tighter.
The Following User Says Thank You to ddawg16 For This Useful Post:
user1007 (09-04-2012)
Old 09-04-2012, 06:36 AM   #3
Too Short? Cut it Again!
Ditto! Definitely use teflon tape for your connections. You do not want to glue threaded fittings.
Old 09-04-2012, 06:58 AM   #4
Rewards Points: 1,578
Most pipe dope is fine for PVC threaded joints; check fine print of your pipe dope container to see if recommended. If so, just wrap some teflon tape 3x's around and reinstall. Using both is many times better than either alone.
bob22 is offline   Reply With Quote
Old 09-04-2012, 07:17 AM   #5
the Musigician
DangerMouse's Avatar
Using fast-drying glue on threaded pvc joints may cause more problems than it solves!
DM
Old 09-04-2012, 09:22 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Glue softens the plastic to allow them to mold together. If you put that on threads, i bet you can guess what is going to happen.
Journeyman Plumber
Old 09-04-2012, 10:32 AM   #7
I wasn't planning to unscrew the fittings. I was gonna clean off the dope, PVC prime and PVC glue circumferentially at the fitting. Check out the pic. See how all the valve pipes are on top of each other? I don't think I can unscrew em. If my plan doesn't work I'll have to cut the pipes and start over.
Old 09-04-2012, 10:34 AM   #8
The leaks are where the PVC elbows attach to PVC couplers
Old 09-04-2012, 10:54 AM   #9
JOATMON
ddawg16's Avatar
I can tell right now that your plan will NOT work. PVC glue will not seal up thse leaks from the outside. It might work for one day....but pvc moves arond a lot with temp. It won't be long before it leaks.
Save yourself some time....do it right now....
Old 09-04-2012, 10:59 AM   #10
DDawg
Thanks man! I was hoping that was what someone was gonna tell me.
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Teflon Tape or Pipe Dope Jupe Blue Plumbing 3 05-21-2011 09:17 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
