Getting The Lead Out - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2011, 11:20 PM   #1
Rewards Points: 562
getting the lead out
I need to get the lead out of cast iron hub . Will a hand held torch get it hot enough to melt out the lead???or does the cast serve as a huge heat sink???
If latter is true what IS the quickest way to get them apart??.
Replacing badly rusted stool flange and elbow right under floor as well as eliminating a shower drain into the side of the elbow. No room to snap and no hub
4just1don is offline   Reply With Quote
Old 07-28-2011, 11:36 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 812
Best to use a drill with about a 1/4" bit. Drill the lead out around the pipe then you should be able to wiggle the pipe out.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Alan (07-29-2011), oh'mike (07-29-2011)
Old 07-29-2011, 12:14 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
P.S. once you get it hot, how do you plan on removing it? Turkey baster?
E plumber has you on the right track. Good luck!
Journeyman Plumber
Old 07-29-2011, 03:28 AM   #4
Rewards Points: 562
thanks Alan and E Plumber for your responses.
Alan- pipe is horizontal which makes joint coming out vertical. Plan was to let Mr. Gravity help me out or if just softened Mr. Beater Screwdriver help out ect.
E Plumber- Will drill and drill,,,once I get it started it rolls out pretty good, but starting is hard part. (its in a nasty crawl space tough to get to) hence an easier solution
Old 07-29-2011, 07:37 AM   #5
Plumb or Die!
Got room to swing a sledgehammer?
plumber666 is offline   Reply With Quote
Is Instant Lead Tester accurate? ksk051182 Painting 5 04-17-2011 09:05 PM
Cost of X-ray to find lead paint? TOTALN00B Painting 1 02-19-2011 02:23 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
