Old 02-10-2012, 01:14 AM   #1
Getting an Inspection. Will my DIY plumbing pass or have problems?
I finished off my basement 1/2 bath by myself and everything works great and no leaks at all....we are selling our house and they are going to do an inspection....do u see any problems in pictures?
thanks
this one is just an electric box I put in....
tibasnatch is offline   Reply With Quote
Old 02-10-2012, 06:53 AM   #2
A "Handy Husband"
rjniles's Avatar
The electric cable is not secured properly.
Is the supply pipe PVC or CPVC? CPVC is OK, PVC is not for hot supply.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 02-10-2012, 08:11 AM   #3
JOATMON
ddawg16's Avatar
The Romex needs to be secured closer to the box....too much slack....in other words....your big loop hanging out there. And it looks like you removed the plastic 'clamp' on one side of the box. The Romex is supposed to be secured at the box entry...some inspectors will ding you for it...others not.
Your plumbing looks like PVC....if it is PVC, not legal for hot water....I personally would never use it inside a house for any water....care to guess what kind of mess your going to have when someone breaks off one of those ends? At a min, I would have ran the pipe to a copper stub secured to a stud. You then make your utility connections to the copper stub....
Me thinks your going to be redoing all of that.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 02-10-2012, 10:28 AM   #4
Uhoh, Did you use CPVC glue (the orange stuff) on your PVC DWV lines?
The sink drain looks like it needs more support.
The excess loop on the romex is fine but the staple should be within 6 inches of the box. Is that 14 awg wire servicing a recepticle? I ask that because it's white and most all 12 awg wire I've seen in the last 10 years has been yellow. I think you'll need and want a dedicated 20 amp circut for the bathroom, therefore 12ga wire would be required. Hair dryers and curling irons suck amprage.
sorethumber is offline   Reply With Quote
Old 02-10-2012, 10:43 AM   #5
Why the long spans between the studs?
Pluming is unsupport for to long a span, no support where the shut off is.
Plumbing installed to close the the face of the stud, should have been in the middle.
Why is some in the wall and some is outside?
If I had to deal with that I'd just cut it all out and start over using Pex.
Unless that inspector shows up with a white cane and a guide dog it's not going to pass.
plummen (02-10-2012)
Old 02-10-2012, 11:29 AM   #6
are you allowed to thread cpvc/pvc straight into copper like that at the T junctions? i always thought you needed a transition coupling that had brass male or female thread on it.
NitroNate is offline   Reply With Quote
Old 02-10-2012, 12:51 PM   #7
well the electric will be an easy fix just restaple....I will try and find a way to support the sink shut off better....tey hot and cols IS the same pipe...thats what the guys at home depot gave me when I told them what I was doing.
its possible they wont even do an inspection its been 4 days of there 10 day period....if i wanted one id want it done asap.....if they do and it fails which sounds like it will...i dont see a huge job for me to rerun it or use the PEX like stated above.
please keep giving honest opinions.
Old 02-10-2012, 04:24 PM   #8
call me E
TheEplumber's Avatar
Inspector may not care- they're not that bright- but, you have too many 90's in the trap arm
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
AndyGump (02-10-2012), plummen (02-10-2012)
Old 02-10-2012, 04:32 PM   #9
Does your contract say that repairs must be performed by a licensed professional? If so, you'll obviously want to fix everything before the inspection.
silversport is offline   Reply With Quote
Old 02-10-2012, 04:50 PM   #10
Is this an inspection by the local municipality for code enforcement? Or is this a private "inspection" arranged by a potential buyer as a contingency for the purchace? If its the latter I'd say you've got little to worry about. If however if its the former get ready to do some work.
Old 02-10-2012, 05:39 PM   #11
Don't like the electrical timer ? box in the first picture I think it should be mounted to wood secure and adequate wire connections.
COLDIRON is offline   Reply With Quote
Old 02-10-2012, 07:09 PM   #12
it is just someone buying my house f they decide to get an inspection.....the grey box u see was actually hung there by the water company themselves.
Old 02-10-2012, 07:41 PM   #13
creeper's Avatar
The reason they haven't scheduled the inspection yet is likely because they are making sure that they get financing first. Why pay for an inspection if you can't get approved for a mortgage. If they asked for an inspection, expect one
creeper is offline   Reply With Quote
Old 02-10-2012, 08:28 PM   #14
Rule #1 never lisen to anyone at a box store. If they knew what they were talking about they sure would not be working for $9.00 an hour.
Rule #2 Read rule #1.
Just took another look. You have primer on just one joint on the PVC all the rest have what's looks like sloped on PVC cement.
Big no no.
Old 02-10-2012, 08:34 PM   #15
call me E
Specially if he wear an apron
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
possibly huge problems with plumbing - extensive post NowItsShowtime Plumbing 5 04-22-2010 08:37 PM
Plumbing inspection home Safety 3 06-17-2009 01:17 PM
Adding Kitchen pass through to an existing opening? sscott0203 Remodeling 7 12-13-2008 04:17 AM
plumbing problems newbie needs help ? blondewolf Plumbing 2 08-30-2006 07:31 PM
