Gets Loose!!!!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2009, 12:34 PM   #1
Rewards Points: 252
Gets Loose!!!!!!
The kitchen sink has two strainers. The tail pieces always seem to get loose and flood the cabinet. They always come loose at the strainer. I have replaced the plastic hand turn (nuts?) I am not sure what you call them, more than once. They screw on to hold the tail piece to the strainer. It seems like maybe I need the metal type instead of the PVC type due to the threads? Or, do I need to replace the strainers? Nothing is hitting the tail pieces. The connection between the strainer and tail piece is the only thing that gets loose. It happens on both sides. It will stay dry and everything seems fine and then Bam. Water inside cabinet and floor.
Thanks for any suggestions.
Old 05-10-2009, 12:52 PM   #2
Sounds more like a problem with the gasket that tightens against the tail piece. This gasket is inside the nut and compresses (and seals) when you tighten the nut. I have also seen the gasket installed upside down. The tapered end goes away from the nut and the thick, flat part is against the backside of the nut. Check to see if the gasket is 1) there 2) installed correctly 3) not broken, since most are nylon.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-10-2009, 02:32 PM   #3
Use metal nuts and a flanged tailpiece washer. The one that look kinda like a top hat.
plumber Jim is offline   Reply With Quote
Old 05-10-2009, 02:41 PM   #4
Was the stainer installed with plumbers putty around the hole? Usually if it is the not can come off and it still won't leak unless banged.
hayewe farm is offline   Reply With Quote
Old 05-10-2009, 06:28 PM   #5
with me, if its plastic threads and leaking, I end up stripping the threads, on the kitchen sink, I like to use the strainers, metal, that have the thumbs screws on the bracket to help tighten it up.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 05-11-2009, 05:56 AM   #6
Rewards Points: 150
Sometimes the threads on the strainers aren't cut deep enough especialy if you use those made in china or taiwan. replace the strainers with a good american made metal strainer and use either plastic or metal slip nuts with a tailpeice washer.
al's sewer is offline   Reply With Quote
Old 05-11-2009, 10:50 AM   #7
Rewards Points: 252
I noticed the threads look very shallow on the strainers. Like they will not even get tight. But the tail piece will tighten and then a few days, a month they come loose again.
So, you suggest replacing the strainers and use the metal slip nuts that come with the strainers?
Should I try the metal slip nuts first or go all the way (strainers too)? Thanks John
Ps....I just remembered that I had to remove the washers (that looks like a top hat) just to get the threads started.
Old 05-11-2009, 03:08 PM   #8
Rewards Points: 150
I would replace the strainers with new ones and before you leave the supply store try putting your tail peice and tailpeice washer on it before you leave and make sure it will work. The tailpeice washer is essential.
Abloy Front Door Lock is loose - how to open to tighten Wayne_in_Canada Windows and Doors 4 09-23-2012 07:48 PM
Loose / Bent Faucet yasman Plumbing 1 03-30-2009 08:50 PM
Vessel sink fits loose on counter top jam12 Plumbing 3 11-20-2008 05:02 PM
Carpet coming loose on the stairs-how to fix? imola ghost Flooring 1 09-22-2008 07:22 PM
help, loose door hinges screws clyde Carpentry 13 12-19-2007 01:31 PM
