Gerber Toilet Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2011, 01:31 PM   #1
Gerber toilet leaks
I have a Gerber toilet and it is leaking at the gasket tank to bowl. I have put a new one on and can't seem to get it right. I have pulled it apart at least a dozen times to reposition the gasket, it still leaks. Is that gasket to slide just over the flush valve or is it to go over the nut also ? It only leaks when you flush it.
Rich 1 is offline   Reply With Quote
Old 12-03-2011, 02:19 PM   #2
Like this...
http://www.theangryhomeowner.com/ima.../gasket_lg.jpg
and this...
http://www.renovateyourworld.com/ima...t_01_large.gif
and this...
http://www.toiletology.com/images/anatomy3.gif
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
Rich 1 (12-03-2011)
Old 12-03-2011, 02:24 PM   #3
Lightfoot's Avatar
Rewards Points: 272
If your'e talking about the donut/spud gasket, it should slip over the big nut also and fit up against the bottom of the tank.. At least that's how i do it. try putting some plumbers grease on it to help it position itself and seal good when tightened. I put it on both sides of the gasket (inside and out).
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
Rich 1 (12-03-2011)
Gerber Pressure Toilet does flush all the way jimrens Plumbing 0 05-10-2011 10:10 PM
Toilet leaks? but not really? gunrock Plumbing 3 04-22-2010 06:20 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet Leaks When Flushed - How to get at closet bend!! OldHouseNewProblem Plumbing 3 12-11-2008 07:24 AM
