Gerber Toilet Double Flushes - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2008, 10:07 AM   #1
Rewards Points: 199
Gerber toilet double flushes
I have a Gerber toilet made in 1993. When I flush, it flushes twice. I hadn't heard of this brand but looked around the net and found it's the last brand actually made in USA! I think maybe only pros install them. I've tried backing off the water pressure a little and also replaced the flapper. What should I try next? Is it worth trying to fix or should I chuck it?
Arlo is offline   Reply With Quote
Old 01-20-2008, 10:21 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Sounds like toilet is a 1.6 gal flush and you did not install the correct flapper for a 1.6 gal flusher.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-20-2008, 11:05 PM   #3
Rewards Points: 199
It was double flushing before I replaced it. I used one of those red flappers that are supposed to fit "most toilets" from Home Depot. I didn't realize there were special flappers for 1.6 toilets. It is a 1.6'r and I've heard that the early ones were quirky. Should I get a genuine Gerber flapper from a plumbing supply house? Thanks for your time and expertise.
Old 01-21-2008, 12:17 AM   #4
Rewards Points: 150
When your watching it,,,what pulls the chain or the flapper up the second time,,,is it too tight??
justdon is offline   Reply With Quote
Old 01-21-2008, 02:36 AM   #5
Journeyman Plumber
Yes or any 1.6 gal flapper will work.
Old 01-21-2008, 06:22 AM   #6
is the water in the tank above the water line??
replace the flapper with the 1.6
ranman469 is offline   Reply With Quote
Old 01-21-2008, 06:47 AM   #7
Master Plumber
Rewards Points: 150
A 1.6 gal flapper usually has a hole in it to release the air and make it drop quicker. Fluidmaster also makes an adjustable flapper that may work, it has a hole you can rotate to the position you need.
jpplumber is offline   Reply With Quote
Old 06-21-2008, 01:25 PM   #8
Rewards Points: 199
Gerber Double Flush UPDATE
I did replace the flapper with one for 1.6. It STILL double flushed. What ultimately worked was cutting back on the main water shut off. I guess the town water supply was thundering into my pipes at too high a pressure to suit the toilet. I still have plenty of water pressure in the shower and sinks.
Old 02-22-2009, 03:08 PM   #9
You can get the right flapper.
http://www.griggindustries.com/servl...ide/Categories
It's a guide that shows the parts by the tank number
fcplumbing is offline   Reply With Quote
Old 02-22-2009, 03:37 PM   #10
plumbing contractor
PLUMBINGITALL's Avatar
I think you have a pressure issue and need's a pressure reducer valve installed.
PLUMBINGITALL is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 01:34 AM
Toilet flushes slowly, but no visible clogs... poorboye Plumbing 4 09-13-2007 11:02 AM
