Gerber Pressure Toilet Does Flush All The Way - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2011, 09:10 PM   #1
Gerber Pressure Toilet does flush all the way
I have recently Gerber power flush 1.6G toilet. It doesn't seem to flush the material all the way down. A lot of pressure water comes out and the bowl water goes down about 1/2 way at the most. Then it circles around and continues to rise while the pressure vessel fills (which takes about 20 secs). I have taken the toilet apart and dumped a bucket of water down the drain to make sure it wasn't clogged. The issue must be in the toilet but I can't find any material. It is really hard to snake the toilet because the path goes up and then makes a sharp turn to go back down to the drain. The drain hole must be aligned with the toilet because I get no seepage out the side even though the toilet is not bolted down yet. Any thoughts are suggestions? Is this just the way these types of toilets work?
Thanks,
-Jim
jimrens is offline   Reply With Quote
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
Commercial toilet vs. Assisted Flush Residential Toilet gatesj1221 Plumbing 3 03-15-2011 11:47 PM
Low Flush Toilet - Water Running ? GBunny Plumbing 2 10-09-2010 07:52 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
