General Plumbing Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2012, 06:53 PM   #1
Rewards Points: 660
I am getting set to plumb my basement bathroom addition and laundry move. I have a rambler with a full and (soon to be) master 3/4 on the main level. My questions:
1. It appears that the hot pipe coming out of the hot water heater is 3/4 straight up and switches to 1/2 as it runs vertical. Would you run 3/4 vertical to get closer to the items you are supplying and then 1/2 when you drop to them? As is, I do not lack for water pressure anywhere.
2. As the house is currently plumbed, all the cold water to the two bathrooms is pre water softener. Wouldn't you want all water to go through the Culligan water softener first, with the possible exception of sprinkler system and outdoor water spigots?
B
Beepster is offline   Reply With Quote
Old 11-13-2012, 08:38 PM   #2
Rewards Points: 616
i would run 3/4 then branch of to 1/2 for each bathroom
water softener is a personal opinion but i agree with what you are suggesting to do
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 11-14-2012, 10:40 AM   #3
Rewards Points: 660
Good to hear confirmation. Any other opinions?
B
Old 11-14-2012, 03:52 PM   #4
Special User
Rewards Points: 1,230
I agree with jaydevries. But read up on WSFU or Water Supply Fixture Units. There may be rare circumstances where 1/2" is adequate, but in most cases you need a 3/4" main line. Each fixture only needs a 1/2" branch by itself, but don't try to supply multiple fixtures from 1/2" unless you have run the WSFU calculation to make sure you can still meet code with such a small pipe.
To give you an example, when we replumbed I calculated our WSFU and found we needed a 1" main line for the cold! (Hot has slightly lower WSFU requirements, so we only needed 3/4" for hot.)
As for the softener, yes, I'd soften everything except hose bibs and fire sprinklers. Though since toilets are usually white, you could probably plumb them with hard water and save a bit on on softener salt without noticing any hard water stains. Probably not worth the extra effort it would take to run separate lines just for the toilets though, unless you were doing a homerun/manifold PEX system.
tylernt is offline   Reply With Quote
general plumbing question chadadco Plumbing 8 07-01-2012 11:11 AM
Installing radiant heating in a basement and general basement questions... CarlsonRower General DIY Discussions 6 12-09-2011 01:32 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
General Insulation Questions Drizzt Insulation 18 11-03-2011 04:12 PM
some random, general plant questions joeyboy Landscaping & Lawn Care 7 11-30-2007 07:34 PM
