-   -   general plumbing question (http://www.diychatroom.com/f7/general-plumbing-question-148565/)
chadadco 06-29-2012 12:45 AM
Can anyone tell me what this is in my garage wall,,,,[IMG]. http:// http://www.diychatroom.com/members/c...-imag0129.jMG]
http://www.diychatroom.com/members/c...5-imag0129.jpg
TheEplumber 06-29-2012 01:46 AM
Originally Posted by chadadco (Post 953783)
That is a clean out plug that is probably located at the base of a drain stack
chadadco 06-29-2012 09:26 PM
Can I hook a drain from a sink to it?? Ty
TheEplumber 06-29-2012 09:35 PM
Not directly to that fitting. It isn't designed for that. You could cut in the proper tee above or below it. The next two questions you need to answer is where does that pipe go? Is it a vent or a drain line?
ben's plumbing 06-29-2012 09:35 PM
yep a clean out plug......:yes:
chadadco 06-29-2012 10:14 PM
I'll check it out but I'm sure It's a drain because its right below kitchen.
VIPlumber 06-29-2012 10:18 PM
My vote is for cutting a tee in above the cleanout.
chadadco 06-29-2012 10:38 PM
Thanks for all the help
Javiles 07-01-2012 11:11 AM
Depending on what the c/o services you may have to branch and vent the new sink installation.
