GE Water Heater Failure - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2013, 04:55 AM   #1
GE water heater failure
Arggggh woke up to a cold shower this morning. Ge SG50T12AVG00 heater with White Rodgers 37C73U837 gas valve. No pilot and certain there's gas available. I hate to just start replacing stuff. Any suggestions or experience in the crowd?
The heater is under two years old and has been fine until now.
64pvolvo1800 is offline   Reply With Quote
Old 05-07-2013, 05:29 AM   #2
biggles's Avatar
did you try relighting it if it doesn't hold the pilot when you release the valve from push down the thermocouple might be shot.. easy change out
Old 05-07-2013, 05:49 AM   #3
Will not relight at all.
Old 05-07-2013, 06:22 AM   #4
Rewards Points: 1,514
Does this water heater have a sealed hatch down below with a glass window to see the pilot light?
If you wait several hours and then try to relight the pilot, does it stay on at least for a few minutes after you let go of the red button but the burner won't keep running?
You could have had an air intake damper trip. This usually needs a serviceman to fix although some homeowners have succeeded in jury rigging a fix.
Old 05-07-2013, 07:38 AM   #5
Well, I pulled the burner out and checked for clear passages to pilot and main by just blowing through both pipes. Tested the igniter and thermocouple output with a torch and fluke. All seems ok. Tested the gas valve by just pushing the pilot valve without anything connected, and got flow of gas. Slapped it all back together and VOILA, pilot lit. Pilot stayed lit. Main burner lit, stayed lit. Hot water is building and so far, ten minutes, burner still going strong.
Is it possible the gas valve has to be depressurized before restart in some case of shutdown?
I did turn the gas off while I disassembled the burner.
I didn't see any over temp device connected anywhere but I suppose it is in the tstat portion of the main body of the valve and unseen or protected against bypass (for damn good reason!)
I guess all I can do is monitor it closely for now.
Seems like I have good airflow and exhaust piping too.
The wife has been here and does not remember any gas going out but then again, the water heater is the only gas device we have that would need a manual restrike.
Things that make you go hmmm!
Thanks for all the help guys and girls.
Old 05-07-2013, 08:05 AM   #6
Rewards Points: 3,130
Glad you have hot water back. I'm frankly surprised that such a new heater doesn't have electronic ignition instead of a pilot light.
Old 05-07-2013, 06:13 PM   #7
Rewards Points: 1,956
You should clean your burner assembly at least once a year. You should also trip off your temperature and pressure relief valve to make sure it is not blocked once a year. You should replace it every three years. You should also replace your Anode every three years. If you replace the anode you will not need to purchase a new tank. You also should drain out the crud from the bottom at least once a year....
Old 05-07-2013, 08:55 PM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,850
and don't forget to brush your teeth before bedtime
MTN REMODEL LLC is online now   Reply With Quote
Old 05-07-2013, 09:40 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 996
Glad to hears your up and runing, keep an eye on it may be the begining of a problem with the magnetic gas valve inside the control. if its under warranty Contact GE they may send you out a new unit (control) before it goes down again.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
