GE Gas Water Heater Thermal Release Device - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2011, 09:36 PM   #1
How do you know if your Thermal Release Valve or Gas Control Thermostat is defective? My pilot stays lit and when I turn dial to higher heat, the burner comes on for a second then both go out. GE says it's probably the TRD. A repairman came out and said it was the thermostat. To check the TRD the burner has to come out. I'm worried that once I get the new thermostat in Tuesday it won't solve the problem, then the repairman will have to return the second time when I order the TRD from GE.
BfairOK is offline   Reply With Quote
low pressure after hot water heater replacement tuffluck Plumbing 4 06-07-2011 03:14 PM
Smelly brown water from water heater timthetoolman Plumbing 2 05-19-2011 09:32 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
