GE 40,000 Grain Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2010, 09:50 AM   #1
GE Water 40,000 Grain Water Softener
We just installed this model. Unfortuneately, where the water supply comes into the house, there is not a drain. A few questions:
1) Can we simply run flexible tubing from the unit to our sump pump/drain area (which is about 50ft away)
2) We put in a 40lb bag of salt? Is that sufficient? Or, is it better to add more?
3) In regards to the recharge function, what is the "formula" that calculates when a recharge is needed??? I ask, b/c we had the unit installed on a Friday, and by Monday (at 2am.......which is the recharge default time), a recharge occured. And, maybe I need clarification on what the recharge function is, and what's supposed to occur? when a recharge is called upon, is the entire water supply in the unit supposed to drain out of the softener and into the drain (or in our case a vynal storage containter)? This was a slight problem, b/c the amount of water from the recharge overflowed our container.
Feedback please!!!
soxcycling is offline   Reply With Quote
Old 04-07-2010, 11:50 AM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
You need to run the line to a drain.
http://www.popularmechanics.com/home...s/1275126.html
will show you how it works. some use more water then other to recharge.
Big N8 is offline   Reply With Quote
Old 04-07-2010, 11:54 AM   #3
1) Can we simply run flexible tubing from the unit to our sump pump/drain area (which is about 50ft away) Yes
2) We put in a 40lb bag of salt? Is that sufficient? Or, is it better to add more? It is sufficient for the initial supply provided the water is above the water level but will need replenishment--the time depends on your water hardness and your water usage.
3) In regards to the recharge function, what is the "formula" that calculates when a recharge is needed??? I ask, b/c we had the unit installed on a Friday, and by Monday Recharge depends on your hardness which you should have programmed into the unit and your water usage. I don't believe there are any other settings available to the user on the GE unit.(at 2am.......which is the recharge default time), a recharge occured. And, maybe I need clarification on what the recharge function is, and what's supposed to occur? when a recharge is called upon, is the entire water supply in the unit supposed to drain out of the softener and into the drain (or in our case a vynal storage containter)? YES This was a slight problem, b/c the amount of water from the recharge overflowed our container.
Feedback please!!!
See answers above.
Bob999 is offline   Reply With Quote
Old 04-07-2010, 06:38 PM   #4
Licensed Master Plumber
If there is a pump in the pit I would not. The salt water is not good for the pump.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 04-07-2010, 07:30 PM   #5
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
I was just going to ask about that. What about if you can't run the line to a drain and have to run it to the sump pimp. Will the water eventually kill the sump pump ??
ryanh is offline   Reply With Quote
Old 04-07-2010, 09:13 PM   #6
yup, eventually being a fairly short time
Old 04-08-2010, 01:05 AM   #7
ryanh's Avatar
Rewards Points: 154
So say someone has a crawlspace and/or no drain near the water softener where else could you run one of those plastic drain hoses too?
Old 04-08-2010, 05:20 AM   #8
You can run it to the outside as long as you dont kill the wifes rose bush.
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Help with Water Softener TTran Plumbing 5 05-27-2009 06:08 PM
Refurbishing a water softener? Good idea? bugmenot Plumbing 4 02-07-2009 06:26 AM
Water softener salt hog sk8z Appliances 5 10-10-2008 06:49 AM
Water Softener wont stop draining help TTran Plumbing 3 08-24-2008 08:16 PM
