Old 08-13-2012, 03:20 PM   #1
Gator bite water shutoff
Installed gator bite water shut off valves and the water flow has been reduced significantly. Is this normal? What can be done to increase flow?
maudedc is offline   Reply With Quote
Old 08-13-2012, 05:02 PM   #2
call me E
TheEplumber's Avatar
No, If these valves were installed on supplies to a single fixture, you've probably dislodged some debris inside the lines. Clean the aerator first.
Old 08-13-2012, 10:01 PM   #3
Doing it myself
Alan's Avatar
Did you by chance install the shutoff valve in the ground?
Journeyman Plumber
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
