Gator Bite & Shark Bite - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2012, 02:40 PM   #1
Gator bite & shark bite
Had to replace the 1" sprinkler supply line that leads from my basement to the outside. Is it ok to use a gator bite or shark bite coupling? I have never used them before.
jamjr74 is offline   Reply With Quote
Old 04-20-2012, 03:00 PM   #2
What's the line made out of?
AZJefe is offline   Reply With Quote
Old 04-20-2012, 03:15 PM   #3
1" copper
Old 04-20-2012, 03:26 PM   #4
Rewards Points: 150
1) Do a search of the forum for sharkbite. There are plenty of discussions on SharKbite and Gatorbite connectors.
Here is the most recent SharkBite Fittings OK?
2) Either in your post or in your profile please let us know where you live. The answer will depend on your local codes.
3) Be ready for a minor flame war. People's opinions of these products, independent of the codes, varies a lot (see 1 above). Personally, I only use them for temporary fixes that are not concealled. (I have so many things on my DYI and honeydo list, that temporary fixes have tendency to become permanent )
4) Heed the warning about removing the white plastic piece (see 1 above).
Yes there are 1" sharkbites that will work on copper. They are about $14 a piece.
goosebarry is offline   Reply With Quote
Old 04-20-2012, 03:48 PM   #5
Yes I purchased a 1" coupling and the job is done. I am just paranoid whether this will hold up over the years. Only time will tell I guess. It is in an open crawl space in my basement so I can keep an eye on it.
Old 04-21-2012, 10:53 PM   #6
It will probably be fine, just out of curiosity, why were you hesitant to use a soldered coupling on copper?
Old 04-22-2012, 06:23 AM   #7
Just because I have never done any plumbing work whatsoever except for some PVC. Have never soldered before. However I gave it a shot and soldered a copper coupling on repaired the issue.
Old 04-22-2012, 07:55 AM   #8
Ravenworks's Avatar
Originally Posted by jamjr74 View Post
Just because I have never done any plumbing work whatsoever Have never soldered before. However I gave it a shot and soldered a copper coupling on repaired the issue.
Good for you,nothing beats failure but a good try!!
Ravenworks is offline   Reply With Quote
Shark Bite fittings Red Squirrel Plumbing 32 03-21-2011 10:58 AM
shark bite fitting Boston Bean Plumbing 6 09-12-2010 12:01 PM
Splicing Shark Bite Jack E Plumbing 11 05-04-2010 05:48 PM
Shark bite! Chuckwagon Plumbing 10 01-07-2010 09:23 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 02:01 PM
