-   -   Gate Valves or Stop and Waste Valves (http://www.diychatroom.com/f7/gate-valves-stop-waste-valves-27/)
Rich 01-02-2004 10:16 PM
Working on the bathroom plumbing. I want to add shutoff valves for the mains into the bathrooms (2 full baths) and to the feeds for the bathtub/shower for each bathroom.
Picked up valves at the two Home Improvement stores. I picked out ones with red and blue handles (hot and cold). I was dry assembling the fittings and pipe and I noticed that the blue handle ones I picked up are "Gate" Valves and the red handled ones are "Stop and Waste" Valves. I can look in the valve and see the difference between the two openings.
Question is: Which should I really be using? :confused: :confused:
BTW - The only 3/4" valves that I could find for the mains are "Stop and Waste" valves.
Rich 01-05-2004 01:40 AM
Job Done...Mostly
I've finished the job, for the most part, just need to cut off some stubs and put the angle valves on and then the Master bath will be back to normal. Need to run some new pipe over to the new bath fixture in the guest bath, but all of the new valves are in (ended up using the Stop and Waste Valves all around).
New question: How likely is it for leaks to develop over time? And will they develop quickly or over a long time?
When I turned everything on, everything is looking good, :) no leaks (right now). I just dont' know for sure how much to trust my solders not to leak down the road. :rolleyes:
Any thoughts?
hatchet 01-05-2004 07:37 PM
Most sweating of copper will develop leaks right off the bat. Typically it's due to water in the line and when you heat it the steam pushes the solder out of the way.. instant leak. I'd be more worried if you have any compression connections. Get good pipe dope for that.
SHR Plumber 03-03-2014 11:57 AM
Congratulations on completing the job with no leaks! Check the joints for leaks the first couple of days and you will be fine. As stated earlier, most leaks appear right away. The washers and seats inside the valves will leak eventually and not completely shut off the water when you need them to. That is a downside to using stop valves. I always use ball valves instead. Your valves are repairable though if you ever have leakage problems when shutting off the water. It seems like you are set for now.
SeniorSitizen 03-03-2014 01:23 PM
Stop and waste valves were designed about a hundred years ago to drain the pipe to prevent freezing and was typically installed below frost line. I'm wondering where the valves Rich installed are draining to when shut off.
jmon 03-03-2014 02:29 PM
Old post from 2004. Good info to know though.
