Gas Water Heaters - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2010, 07:50 AM   #1
Gas Water Heaters
How do I install two gas water heaters side by side?
seatoo is offline   Reply With Quote
Old 12-17-2010, 07:54 AM   #2
the Musigician
DangerMouse's Avatar
HI and welcome to the forum.
We'd need a few more details to assist you.
Why do you want two? Gas or Electric?
Two different outputs?
etc...
DM
Old 12-18-2010, 11:54 PM   #3
http://www.hotwater.com/bulletin/bulletin64.pdf
Try the above link. Should help you out.
Work4living is offline   Reply With Quote
Tankless Heaters on hard water Pstein Plumbing 0 08-25-2010 06:18 PM
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 04:57 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 07:52 PM
