Gas Water Heater Wont Light - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2012, 08:18 PM   #1
gas water heater wont light
Hi, I have a AO smith Promax 92111829000.. It wont light. I ordered a HSI Assembly.
Can I light it manually, until the parts arrive? If yes, how do I do it?
Thank you
EastCoastMaico is offline   Reply With Quote
Old 06-20-2012, 01:51 AM   #2
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
what's it doing or not doing is it not lighting or not staying lit. is the electrode sparking at all. it's not often that iv'e had to replace that usually it's the pilot assembly or the thermocoupler some units have when the thermocouple fail there is a built in or inline varistor i think that what it is i will put in the pilot assembly i have cut the varistor and install a therocouple but i don't recommend doing it and i'm sure it voids the warranty and it has worked and not worked. do you have thermal cut off switch? if so check
wctekkk is offline   Reply With Quote
Old 06-20-2012, 11:45 AM   #3
Hi, The igniter comes on, then i hear a clicking, then igniter goes out..
Thank you
Old 06-21-2012, 02:55 AM   #4
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
what kind of w/h model and serial #
Old 06-21-2012, 09:26 AM   #5
I installed a new ignitor.. solved the problem
Thank you
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Water heater won't light adfuhrer HVAC 1 12-10-2010 03:59 PM
Water heater won't light adfuhrer Plumbing 0 12-10-2010 03:11 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Pilot Light Won't Stay Lit on Water Heater jdolan HVAC 4 07-23-2010 05:42 PM
