Gas Water Heater, Water Not Hot Enough - Thermostat Or Sediment - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2010, 11:00 PM   #16
I'm not 100% sure, but I don't think BW water heaters offer homeowner tech support. They advertise themselves as "just for professionals" water heaters, and I just checked their website and it said you'd have to contact your plumber for assistance. I would contact local plumbing supply houses and find out which of them is a BW rep. You'd more than likely have to order the parts from them anyways, so it saves a step. Reading what you've written, it sounds like the gas control valve is starting to fail, time will make it worse. Take care of it now, before the warranty period expires
the_man is offline   Reply With Quote
settings for indirect water heater doug32 Plumbing 0 07-14-2010 06:04 PM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 09:30 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
Water heater sediment Pete Moulton Plumbing 2 11-18-2008 07:19 PM
