Old 12-24-2011, 06:10 AM   #1
Question
Gas Water Heater w/ Electric ignition - no pilot
Hi All,
I have an American Commercial DCG3 Series Gas hot water heater -
replaced the Pilot valve, and pilot ignition assembly.
The pilot ignition sparks, the pilot lights , the main gas valve opens, hot water is heated - GREAT!
I turn down the thermostat , it turns off , turn it up , pilot lights everything works fine.
I run out the hot water it cools down and the pilot does not light...
The Ignition control module (ICM) is sending 24vac to the pilot valve, the pilot valve is brand new (Resistance is across the Pilot solenoid), THe pilot tube is clear, the electric ignition is arcing....but the pilot light does not light???
What is going on ??
I am baffled??
Please help
Sparkus is offline   Reply With Quote
Tags
electric ignition, gas hot water heater, no pilot
Rheem 40gal water heater - Pilot won't stay light...thoughts ? anku HVAC 10 05-26-2013 03:55 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
selecting an electric water heater reds_21 Appliances 7 05-23-2009 02:48 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
