- Gas Water Heater Vent - - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2013, 12:59 PM   #16
Rewards Points: 1,958
Please do not kill the occupants of your house nohoch.. Carbon Monoxide is a deadly gas and you may go to sleep one night and never wake up... Has happened many times.
Old 05-13-2013, 01:07 PM   #17
Plumber
Unless it's this guy.
DidIDoThat is offline   Reply With Quote
The Following 3 Users Say Thank You to DidIDoThat For This Useful Post:
Ghostmaker (05-13-2013), hvac benny (05-13-2013), MTN REMODEL LLC (05-13-2013)
Old 05-13-2013, 09:15 PM   #18
Ok, thanks all for the help, This is how I found the house, I wasn't planning on keeping it this way.lol. I was looking at how to fix it right, the pvc is from the gas furnace and the 3" metal vent is from the GE 50 gallon gas water heater.
nohoch is offline   Reply With Quote
Old 05-13-2013, 09:20 PM   #19
Sorry if I worded it wrong I mainly put the pipe I had left over to show you guys where it was placed currently in the house and what I needed to do/order in order to vent it properly and if it was possible to have something flush mounted to the wall, I did a search and mentioned being 5 ft from windows, however I was planning on raising the vent pipe, I wasn't sure how to work around the electrical box properly so it looked the best it can. This post, although I was asking a different question at first was mainly a starting point for my research. I greatly aprreciate the input, and by no means meant not to contact a professional on helping me with some of the work, I was looking into your guys opinion on how you would go about venting this properly.
Old 05-13-2013, 09:26 PM   #20
An old Tradesmen
Rewards Points: 7,412
They also make oval B vent. So if you have a wall cavity near by, you could run it up a wall and out your roof.
Old 05-13-2013, 10:07 PM   #21
You have to take it out the roof. So you either use B vent and build a fake chminey or better yet buy a power vent Hot water tank. That can vent out the side of the house.
Old 05-13-2013, 10:35 PM   #22
Oval b vent can only be used with a recessed wall furnace. You may be able to use it with other appliances, but they need to be approved to be vented with oval b vent.
hvac benny is offline   Reply With Quote
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Why can't a water heater vent be extended? Toller Plumbing 6 02-21-2013 08:26 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
