- Gas Water Heater Vent - - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2013, 09:27 PM   #1
Do they make a flush mount vent for the side of your house?
Kinda like the dryer vent for gas vent line?
It will be installed on a block wall
nohoch is offline   Reply With Quote
Old 05-10-2013, 01:02 AM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 984
Ive seen a few over the years not sure if they were custom made or store bought, much nicer look then the round.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-10-2013, 09:24 AM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,444
Not sure if you literally meant "flush".
But would not it be similar to a side vented gas fireplace vent?
Never seen it for a gas dryer.... but seems there should be something similar.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-11-2013, 09:44 AM   #4
yes, I have seen a few placements, is there anything wrong with doing this? My water heater will be vented outside through the block wall, my electric meter box/disconnect is directly above that... and it sits right inbetween 2 windows. My thought is I have two options...90 it around the meter and then go up and vent right beside the mast (left or right) or find a flush mount. I have done some research and seen that it is a good idea to put it at least 12" off the ground.
I have attached a picture of the area. dont know what would be the best option functionally first and then asthetically pleasing also. Vent is temporary stuck out to show placement not staying there.
Old 05-11-2013, 09:45 AM   #5
Old 05-11-2013, 12:02 PM   #6
Rewards Points: 1,706
Your venting a metal flu hot water tank through your side wall below windows... Not planning on living long are you?
You need a power vent hot water tank. The tank you are using needs a chimney through the roof in Class B metal flue with a roof cap.
http://www.ventingpipe.com/type-b-gas-vent-pipe/c1760
Old 05-11-2013, 01:46 PM   #7
An old Tradesmen
Rewards Points: 6,140
You could use a Trane Bayvent termination on a direct vent water heater. It only sticks out a few inches, and can be painted.
Old 05-11-2013, 06:50 PM   #8
Rewards Points: 582
aganist code to vent a draft hood appliance through side wall....like a water heater.....you have to use a power vented heater that vents with pvc pipe..ben sr
Old 05-12-2013, 04:35 AM   #9
An old Tradesmen
So far the OP hasn't said what kind of water heater he has.
Old 05-12-2013, 07:43 AM   #10
Rewards Points: 582
you are right but he has a 4" b vent sticking out of the side of house ....Iam thinking this is what he is talking about....and just in case he's thinking he can vent a drafthood ..????? good point though.ben sr
Old 05-12-2013, 07:45 AM   #11
Rewards Points: 582
hey bt read his post again
Old 05-12-2013, 07:48 AM   #12
An old Tradesmen
I didn't take notice to that B vent sticking out. Yep, it has to go up past the roof. And must be B vent, not plastic. Thanks for the catch. I think I should go and get new glasses.
Old 05-12-2013, 07:53 AM   #13
Rewards Points: 582
I only said pvc because he could power vent heater to side wall and be done with it....ben sr
Old 05-12-2013, 07:56 AM   #14
An old Tradesmen
I saw the PVC already sticking out, and thought it was for the water heater.
OP, if you add a power ventor to your water heater so it can be side wall vented. Often they are noisy, and most people end up hating them.
Old 05-12-2013, 08:55 AM   #15
That vent, if for a natural draft water heater, is definitely wrong, as others have said. Also, you may want to check your local codes on distances between regulators and mechanical air intakes: the intake for what appears to be a high efficient furnace needs to be 10 feet from a natural gas regulator by my code (Canadian B149). Yours may vary, but worth a look.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
ben's plumbing (05-12-2013)
Water heater issues?!? NJdan Plumbing 1 06-04-2015 08:42 PM
Why can't a water heater vent be extended? Toller Plumbing 6 02-21-2013 09:26 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
