Gas Water Heater With A Small Pressurized Tank On Top - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2012, 10:32 AM   #1
Gas water heater with a small pressurized tank on top
This small tank (Therm-x-trol) has sprung a pin sized leak in it, I have bled off the pressure and turned off the water to the heater. Is this easly replaced, or do I need a service to do it?
tcason is offline   Reply With Quote
Old 03-03-2012, 10:56 AM   #2
It's a pretty straight forward process. Could you post a pic so we could see what you're dealing with?
VIPlumber is offline   Reply With Quote
Old 03-03-2012, 11:30 AM   #3
Having trouble with my new phone. Sorry, not to savy with it.
Old 03-03-2012, 12:16 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Turn off water and open faucet to relieve pressure. Unscrew old tank, apply teflon tape, screw on new tank.
Coastal South Carolina
Old 03-03-2012, 12:54 PM   #5
Thank you for the help. Recieved the same info from a friend. Just saved $225.00 in labor from a service!
Old 03-03-2012, 01:10 PM   #6
A "Handy Husband"
rjniles's Avatar
Also read the instruction sheet on pressurizing the tank, although they usually work OK out of the box.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
H2OwTo Pressurized Water Tank problems Gary5579 Plumbing 4 12-11-2011 07:25 AM
Raising Water Heater Tank doesntmatter Plumbing 6 09-30-2010 10:05 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
