Gas Water Heater/shutting Water Off/vacation? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-29-2012, 03:16 PM   #1
Gas water heater/shutting water off/vacation?
In the past, when I am spending more than several days away from home, I have always shut off the main water to the house and turned the water heater (gas) down to 'vacation' mode. I have heard horror stories about leaking pipes when people were away for days on trips. I am now wondering if this is a bad idea. Am I somehow creating a dangerous situation with the water heater? I have no experience turning on/off the water heater and worry about dealing with the gas should I turn it completely off. I am not sure what to do at this point for my next trip.
socaller is offline   Reply With Quote
Old 08-29-2012, 03:57 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
I see no issue with turning off the water supply and setting the WH to the vacation (pilot only) setting. What are your concerns?
Coastal South Carolina
Old 08-29-2012, 04:58 PM   #3
I didn't know if there would be concern about water being pulled from the water heater into the system, for whatever reason (I have heard of something about pressure in the lines or lack there of). If there is no water circulating through the tank, does the water level drop over time? What happens to a gas water heater if has no water in it? Does it just act as a storage tank if it is on 'vacation' and the water main is turned off?
Old 08-29-2012, 04:59 PM   #4
Rewards Points: 6,652
Nothing happens. It will just sit in the tank.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
