Gas Water Heater SHot Flame Out Bottom - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2012, 01:08 PM   #1
Gas Water Heater SHot flame out bottom
Question. I replaced my whole burner assembly on a Whirlpool water heater. I then replaced the whole thermostat control. When I went to ignite the pilot, it would not stay lit. I held the red button off and on for around 25 minutes. There were two wires that were running from the therm control to the door. I did not have them connected. I connected them and then the pilot lit. I turned the gas control knob to on, and flames shot out the bottom of my water heater. It was just a burst of flames and then there were no flames. I left it for about ten seconds then shut it off. Any ideas as to why that happened. I shut off the main gas line. I am thinking that when I was lighting the pilot, too much gas was in the burner assembly seeing as how long I held the red button. Any thoughts?
Kevin11bravo is offline   Reply With Quote
Old 05-31-2012, 01:57 PM   #2
Rewards Points: 1,294
When you say...
do you mean the burner was not lit after this or was it lit and burning OK. If the burner was burning Ok (nice blue flame)then try and relight it again following the directions on the tank. Sometimes when water heater burners start up the flame will "roll" out the opening briefly. This is why it is important to have the safety covers in place when they are in operation.
danpik is offline   Reply With Quote
Old 05-31-2012, 02:00 PM   #3
Yes it was still lit. I peeped into the view port and it appeared that the flame inside was little larger then usual. I just figured it was burning up a little extra gas that may have been in. I turned it off anyway as i didnt want to damage anything.
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 02:24 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
