Gas Water Heater Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2011, 12:29 PM   #1
Gas Water Heater leaking
I have a 50 gal AO Smith hot water heater that seems to be leaking. Problem is, I can't find a source. I look around the top inlet and outlet connections, no leak. I look around the release valve, no leak. I look inside below the firing chamber, no water. But under the base, there is a puddle and it keeps coming out very slowly. Any suggestions on where to look for leakage, and how?
Thanks in advance. Tim
pressingon is offline   Reply With Quote
Old 12-10-2011, 12:40 PM   #2
Sounds like tank leaking
Service plumber is offline   Reply With Quote
The Following User Says Thank You to Service plumber For This Useful Post:
plummen (12-10-2011)
Old 12-10-2011, 12:58 PM   #3
Ok--tank leaking, but how do I check that? and where is the most likely place that it would leak?
Old 12-10-2011, 04:00 PM   #4
Rewards Points: 340
If you have eliminated the inlet, outlet, and pressure - you are looking at replacing it. How old is it?
They tend to fail completely on Christmas eve....Murpheys law.
tribe_fan is offline   Reply With Quote
Old 12-10-2011, 04:08 PM   #5
DIY staff
Rewards Points: 7,174
The tank has a rust hole --no fixing that---sorry.
Tags
leak , natural gas water heater , plumbing
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
